Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: ger on March 02, 2007, 12:41:40 AM
Hi Folks,
As you may recall I'm doing a disk conversion on my 500 using uprights from a very rusty BIS. Stripped the stub axles off of the BIS today, was hoping to use the spring as well but its totally shot, all bent by rust between the leaves, looks terrible!
The stub axles are also pretty rusty and tight. So tonight I thought I'd begin stripping them. Got the bush out eventually, had to saw thro the sleeve in the top of the upright .
The manual covers kingpin replacement in a few easy steps.....I'm guessing that its not as simple as that.
Anyone got any experiences\tips to share??
Gerry
I'll be listening in very carefully, as am at exactly the same stage. Have the new brakes and refurb kingpins etc, but have no idea how to put the kit together or fit it.
Do you also need flexi hoses for the calipers to fit to the old pipe? If so, will ordinary uno ones work, or will you need those expensive 126 ones?
Speak to Tomasz at TRS, he can provide what you need at a very reasonable cost !
[email protected]
Gerry
here's an old thread that may help
http://fiat126club.co.uk/forum/viewtopic.php?t=1169&highlight=reamer
take care if you are using an adjustable reamer, the 2 bushes have to be reamed inline.
If you can get the kit with the bronze bushes (instead of nylon) they are reputed to last much longer?
please excuse my complete ignorance but.....do the nylon bushed items still need to be reamed? If so, does anyone have a suitable reamer for hire/loan/sale??
Had a look on the previous thread, can anyone confirm the size and length of reamer needed? ('89 BIS)
Thanks Folks !
Gerry
