Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: bis13 on February 18, 2007, 04:30:05 PM
Title: ooops broke all me cars......
Post by: bis13 on February 18, 2007, 04:30:05 PM
here this will cheer you up. broke me wifes car.... broke me own car .... and bought dajwids car and broke that as well..... all in all a good weekends work . oh and also my bis is broken . ho hum , but at least i have my sanity!!!!!!!!!!!
wifes car gear/ driveshaft ?
mine changed head and it now wont start. changed coil , points , condensor, ht leads, plugs . checked valve clearances 3 times.  had enough i might just pull the engine out and do what i have planned with engine and car.
polski fiat left hooker non starter , clutch problem plus starter agro , will look at it tommorow and cry....
bis i give it a kick every now and then to make me feel better...
Post by: 126dave on February 18, 2007, 05:14:40 PM
no 1,see my other post
no 2,have you tried a tow start? or slave a good battery in? and checked for juice?
no 3.havent a clue  :wink:
no 4...dont kick any 126  :evil:
Post by: fiatfsm on February 18, 2007, 06:20:31 PM
LOL, maybe you should try Novas Mick, no-one will mind you kicking those! BTW, it is in fact perfectly OK to kick a BIS :lol:
Post by: nathan126 on February 18, 2007, 09:04:31 PM
......stay away from my BIS   :evil:
Is it normal to have so many people wave at you when going along in a 126?  :lol:
Post by: bis13 on February 19, 2007, 01:14:32 PM
it gets worse... i looked at car this morning and had a weak intermitant spark , then it stopped altogether , it seems that the dizzy is not being turned removed rocker cover and the valves are not openning or closing .
pulled out dizzy and as engine turned over could see that cam shaft is not turning but crankshaft is. so at this point i shall retire this car and get on with sorting the engine/car properly .
Post by: hudsonhenry on February 19, 2007, 03:17:44 PM
sounds like a snapped camchain
Post by: bis13 on February 19, 2007, 03:55:11 PM
yeah when i turned over the engine it sounded like the gear is rubbing on the chain links ( do you know what i mean, sound wise?), well now its gonna get "JUICED!!!" ha ha ha . ps i have 2 turbos....
