For Sale & Wanted => Wanted: => Topic started by: paulisa on February 15, 2007, 11:11:06 AM
I need a speedo for my 126 fsm mine blew up had it in bits today and its toast so if anyone has a complete good speedo with the pod would be better please let me know how much Thanks Paul
is that the binacle as in the later model (like the bis?)
yes it looks just like the bis i would imagine one of the bis ones would fit fine
right then i will whip it off in the morning , but beware when you get it if the milage is higher or lower than your original it must be noted and made aware to any future buyers also do not attempt to amend the milage to match yours . i took one apart out of curiousity and it is an impossible task to rebuild and the reverse drill technique takes forever.
pm me your adress and i will post it too you in the morning , and before you ask all i want is £100!! no only joking , just send me the postage cost back , its an aircooler you have isnt it ? are there any bits compatable with the bis you need as i am pulling one apart before i crush it?. (i dont have doors, bonnet . ) cheers mick
