Fiat 126 Chat => Tuning & Customising 126 Models => Topic started by: Marek on January 28, 2007, 09:23:49 AM
Title: Tachos and other gauges
Post by: Marek on January 28, 2007, 09:23:49 AM
Heya,
curious to know if anyone has any thoughts on setting up a tacho, i'd love to know what revs the car is doing.
since the stock gearbox doesn't have a tacho, we need to come up with some other solution, only thing i can think of is by taping into the distributor and doing some crazy electric circuit board tricks..
another idea, what other gearboxes bolt onto the 126 that has a tacho?
looking forward to some interesting responses.
Post by: 126dave on January 28, 2007, 09:40:29 AM
hi Marek,there are various ways off doing it,i used a harley davidson sportster rev counter,(thanks nigel) its used to low power and vibration  :lol: ,off ebay,works a treat wired into the coil and power.
red lines at 6k ish rpm as well,tho i try to keep mine down to 5k.
check out the garage pics and you can see where i mounted it on the dash board.
i also fitted a live oil pressure gauge,i use a smiths one,again from ebay,the oil pipe just connects to the pressure sender in the block,flexi pipe from a boat fitters/chandlers connects the lot together,i prefer live to electric sender,more accurate.
thats it in my cockpit, apart from the switch for the rear deck and the warning/reminder light for the fuel pump
hope this helps  :D
Post by: Marek on January 29, 2007, 01:48:41 AM
that's brilliant, i am on ebay now hunting one down haha
i'll make sure i take photos and document the process
thanks heaps,
Marek.
Title: Re: Tachos and other gauges
Post by: Dom on February 23, 2010, 11:02:13 AM
I've just bought this
http://cgi.ebay.co.uk/harley-davidson-rev-counter-tachometer-dyna_W0QQitemZ260551281488QQcmdZViewItemQQptZUK_Motorcycle_Parts?hash=item3caa110b50#ht_500wt_924
In the hope that i could wire it into my 500. Not seen one before, so bought it out of curiosity as much as anything else. Anyway, I should have done some more research into whether or not it could be made compatible.
I was hoping i would find some wires out the back that i could cut and splice to fit into the circuit - instead however there is just a 6 pin scart like socket and nothing else :-(
I have spent all morning looking for a suitable connector/wiring harness/adapter/anything! to no avail!
Should i just put it back up for sale?
Rear view
Post by: RSPSTEVE on February 23, 2010, 11:46:54 AM
Is this any good?
http://cgi.ebay.co.uk/FIAT-500-126-GEARBOX-REV-COUNTER-MECHANISM_W0QQitemZ200434185153QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item2eaacef3c1
Post by: Dom on February 23, 2010, 12:10:56 PM
I think that is just the speedo drive.
The Harley Rev Counter/Tacho is electrical, so I was hoping it would work off the coil, however I was expecting wires out the back and not a socket
Post by: Dom on February 23, 2010, 12:33:11 PM
I've just found these images on a Harley forum
http://linson.us/harleydavidson/sportsters/bertshowto/berts_how_tos__tachometer_instal.htm
This is the exact Rev counter i have. Where can i get the connector/wires pictured?
I would ask on the forum, but it was posted in 2003!
Post by: Eklipze3k on February 23, 2010, 01:23:08 PM
Based on that guide, it an original Harley accessory so I would imagine they would carry spares. Try contacting HD-UK or your local HD dealer - http://www.harley-davidson.com/wcm/Content/Pages/Utility/hd_contact_us.jsp?locale=en_GB&bmLocale=en_GB
Title: Re: Tacos and other gauges
Post by: 1973/126 on February 23, 2010, 01:26:35 PM
 Or you could try American eBay.
Post by: tiny126 on February 24, 2010, 06:36:13 AM
How about a standard off the shelf aftermarket tacho. I have a brand new one in my loft that I bought about 7 years ago when I was into mk1 MR2's but never fitted. It has a change light and you can also change the background light colour. You just wire it to the coil and power supply (I fink). The make is auto tech or something. I bought it from Halfords and it was only £50 ish. I willl check the make and model if you are interested.
Post by: bobblehead on February 24, 2010, 07:12:49 AM
i fitted a rev counter on my mini simple as .... just fed a lead to the coil and i think another to a earth and that was it?
i think ??? was when i was 17 .... along time ago ? ...
anyway trust me , was 2 wires and no hassle
Post by: Eklipze3k on February 24, 2010, 10:43:18 AM
The problem with the ones from Halfords (IIRC) is that they won't work on anything smaller than 4-cyl
Post by: Pete126 on February 24, 2010, 11:36:10 AM
If you know a little about electronics and can use a soldering iron Velleman do a digital tacho kit No K2625 and can be used on 2-4-6-8- cylinder engines.
http://www.esr.co.uk/velleman/k2625.htm
Post by: Rusty's Uncle on February 24, 2010, 12:52:08 PM
Electronic Gizmos  ::)
I guess it would make no difference if you were running a standard or twin spark coil set up  ???
Post by: tiny126 on March 03, 2010, 10:37:28 PM
Thanks Eklipze3k, Saves me trying to fit it.
Rob
Post by: charlie on March 28, 2010, 11:16:54 PM
Did you find a connector for this tacho? As you only have to connect three wires couldn't you just use a similar shaped crimp connector, or solder them on?
I've just bought a mechanical tacho, i was thinking of running a cable off the distributor shaft (i've got no rotor arm), but it would require fabricating quite a few parts.
Post by: Dom on March 29, 2010, 10:12:31 AM
I gave up searching for suitable connectors and ended up, as I so often do, selling it back on eBay for a substantial loss!
The local Harley shop didn't have any as they come as part of the complete wiring harness and were not sold separately.
Post by: bobblehead on March 29, 2010, 10:52:14 AM
why not get a rev counter from a monkeybike ?? the exsist you know and they work off one cylinder dont forget he he :)
Post by: ape20ff on March 30, 2010, 04:29:59 PM
Hallo to everybody.
Everything is interesting. Maybe I'll be wrong but I' like to say something.
According me, better to use an electronic tacho, simpler and cheaper.
There are universal tacho that have a switch to select cilynders number.
Once upon a time there was a led tacho building kit made for 126. Very cheap, maybe 5 pounds. I'mnot able to find anymore.
The site should be this:
http://xlabs.pl/
If somebody finds new... make us know.
I don't know about jaycar kit but in confront of vellman one has more numbers on display:
http://www.jaycarelectronics.co.uk/productView.asp?ID=KC5290&CATID=25&form=CAT&SUBCATID=347
I don't think that wasted spark mode is a problem because the coil is always one so the number of ignitions too but it happens on 2 cylinders meantime.
Once upon a time tacho gauges were sold here too:
http://www.autoquariat.at/englisch/spare/stpu.htm
I think that can be used tacho from 2 cylinders 4 stroke motorbikes(as you already do) but from 1 cylinder 2 stroke as for exemple one made for vespa that doesn't reach high rpm so it will more accurate.
If you know what to change you can use tacho from 4 cylinders:
http://fiat126.hu/?p=79&a=147
The problem could be that the tacho can work fine with your ignition,I can't add something more but an exemple only:
http://www.ovingtonpaint.com/fiat/id5.html
I hope to learn something more.
Thanks a lot.
Good bye
Post by: ape20ff on June 13, 2011, 10:48:35 PM
Hello.
Take a look:
http://www.youtube.com/watch?v=GAqxoZXTQkA&feature=related
Have you see the digital tachometer?
Do you like it?
(http://img13.imageshack.us/img13/9246/tachometer.jpg) (http://imageshack.us/photo/my-images/13/tachometer.jpg/)
It's avaible in three different display colours,green,red and blue.
Easy to install,only three wires, a +,a- and wire to twist around an ignition cable like a timinglight.
They make tachometer for every engines,2-4 stroke,diesel,gasoline,1,2,3...cilynders.
You must only specify where are you going to install it .
For further infos contact:
[email protected]
They make gauges for E.G.T. and so on.
Bye.
Post by: nrg19uk on June 14, 2011, 07:33:49 AM
I brought one of these of eBay 180571784416 cheap as chips but doesn't seem to work correctly! The numbers jump all over the place and it never seems to give a solid reading!
I also brought matching oil pressure/temp and volt meter, The volt meter needle has stuck round off scale voltage and
The oil pressure and temp gauge have worked faultlessly.... Buy cheap buy twice I suppose  :cry:
Post by: Aaron on June 14, 2011, 12:32:15 PM
I had quite a bit of stuffing around with one of these over the last year,http://club126uk.co.uk/smf/index.php?topic=4164.msg34608#msg34608.
Basically, if you're running the dual outlet coil set-up I found the system produced quite a high number of spikes which buggers up the signal to the tacho, hence all of the numbers will seem to bounce.  If you look at my last post in the above thread this links to a tach filter which you can make which can cure the problem.  It stabilised the digital tacho I originally tried until 3000 rpm was exceeded and then the crappiness of the gauge came to the fore and it all fell over.
Using a quality gauge (harley or buell), with out the tach filter would jump all over the place but once the filter is added it's steady and reproducable.
Unless you pay top dollar on eBay with these digital gauges, the quality will be suspect.
Post by: thepuddlejumper on June 14, 2011, 12:40:18 PM
I fitted a Harley gauge to my 126 and it worked fine, did not jump about, only had it wired temporarily for a day or two, what is the tach filter?
Post by: Aaron on June 15, 2011, 05:19:42 AM
It's basically just a capacitor, resistor and diode.  It's explained here http://www.camaros.net/forums/showthread.php?t=173302&highlight=tach+filter and you just make it yourself.  From what I understand (and that's not much mind you), electronic ignition circuits can cause transient spikes from the coil which can drive electronic tachometers mad giving jumpy readings.
When putting the Buell tach on my 126p, taking the signal from a spare lug on the twin spout coil, i got the exact symptoms of random behaviour with no real reading.  All I had to do was make up the filter as described in the link above and it cured the problem.  I'm starting to think from the 126 standpoint that it may be a peculiarity to the twin spout coils.
