Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: mattlucas on January 15, 2007, 08:14:40 PM
Title: PLEASE HELP! points
Post by: mattlucas on January 15, 2007, 08:14:40 PM
ok i ve tried a new carb and rus for about 10miles later cut out and wouldnt start again  a freind of mine looked at it and said it could be the points we had a look and unless its diffrent to any other cars then they need ajustinddoes any body know how to do this any sugestions greatly recived many thanks
matt
Post by: Utterly-Butterly on January 17, 2007, 08:21:00 PM
Just fit a new set in, not worth the messing around with existing points.
If BIS and if using M. Marelli distributor set them at 0.37 - 0.43
If BIS and if using Zelmot distributor set them at  0.47 - 0.55
Regards
Steve
Post by: phreak97 on July 12, 2007, 01:58:35 PM
to get you out of the poo you can bend them apart and the car will run, probably a bit rough, but it will run. otherwise i thought there was a screw for adjustment?
