Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: moopster on December 28, 2006, 03:27:49 PM
Title: Does anyone have a fiat 126 bis carburettor for sale
Post by: moopster on December 28, 2006, 03:27:49 PM
Hi, my bis starts fine and lasts for about ten miles until it conks out. I got my uncle to take a look at it as i'm rubbish with mechanics and he told me that he had cleaned my carb out, as it was full of gunk. A few weeks later the same thing happened, and he told me that i need a new carb. So does anyone out there have one for sale?  :sad:
Post by: Chris Lakin on December 28, 2006, 03:45:08 PM
hi mate welcome to the forum, have you tried putting an inline fuel filter in? sounds like your jets are getting blocked from crap/rust built up in your fuel tank.
give that a go first, fore sake of 99p fuel filter.
Post by: gregs656 on December 28, 2006, 05:23:25 PM
agreed, throw a fuel filter in there, will only take 5 mins
keep an eye on it, you dont really want tht getting blocked up as well
it may be worth flushing out the fuel tank, im not sure if they have a drainage plug though.
Title: Thanks for the tip
Post by: moopster on December 31, 2006, 10:55:56 AM
Hi guys, thank you for the tip, I will let you know if it works.
Happy New Year. :)
Post by: gregs656 on December 31, 2006, 12:13:46 PM
yer do
its quite a common problem on older bikes and cars
part of the problem is that fuel stations put sand in the bottom of the tanks to prevent condensation in them.
which is great and it works, but its a pain once the sand makes its way into your tank!
have a good one
Post by: mattlucas on January 02, 2007, 02:03:25 PM
im having exactly the same problem with my bis im putting a fuel filter on as soon as i can
Post by: Chris Lakin on January 02, 2007, 02:26:22 PM
nice one matt, put it before the fuel pump (on the inlet line)
this will keep the pump nice and clean too.
i recommend one of these, you can clean them out and they look good.
(http://www.dropshots.com/photos/73614/20061103/084811.jpg)
(http://www.dropshots.com/photos/73614/20061103/084812.jpg)
you can get them for a £10er off ebay,
Post by: ger on January 02, 2007, 03:58:45 PM
I have just bought a 126 BIS for parts...(the body is REALLY bad). I'm told the engine is a good runner. So if you are still looking for a carb, let me know..
I only need the hubs/stub axles/ wheels.
Gerry
Title: still having probelms, so do i need to replace the carb?
Post by: moopster on January 06, 2007, 02:11:25 PM
Hi, I have just put attached an inline fuel filter just infront of the fuel pump. I took it for a spin and the same thing happened, after about ten miles it conks out. I originally thought it was overheating, but the temperatur gage is only at mid point. I does seem to be as though the car is starved of fuel when it break down though. I brought it in October and it is in amazing condition. It's like brand new, it was dry stored in a barn for years and has only done 4.5k miles. I have had quite a few teething problems though, because it had been standing so long.  Can anyone help?:???:
Post by: Chris Lakin on January 06, 2007, 03:10:37 PM
ok well, at leat there is now a filter there, thats a good start, it will stop anything blocking the jets, (otherwise you will be forever cleaning the jets)
often a leaky carb float can make it seem like its starved of fuel, but whats actually happening is there is too much fuel, as when the float become heavy (becaus its full up/weighted with fuel) it opens the needle valve to allow msore fuel in. (just like a toilet cistern) This is what happened on my BIS, when i first got it running.
you need to remeove the top of the carb, and take out the float, (big float, brass looking thing) take it out and give it a shake see if you can hear any fuel inside, also stick it in a bowl of water and see if bubbles surface. Also try a new needle valve, get a carb service kit from www.ricambio.co.uk give them a ring. (you dont get a carb float)
i have only just thought, i think its your fuel pump, only back in september i drove from london to yorkshire, for about 15 miles my car was running beautifully, then all of a sudden it lost power and the car jurked, if i pulled over and let it cool for half a minute it would be fine again. When i got there i changed fuel pump and not a prob since, I would advise getting a new fuel pump (£20) and carb repair kit.
The best thing you can do is replace all the bits, you know its a fuel related problem so its going to be either fuel pump or carb, the fuel pumps rust internally especially when not used frequently (yours was in a barn for years i imagine?)
hope this helps
Post by: moopster on January 06, 2007, 03:47:56 PM
Hi Chris, thanks for the tip. I have to wait about an hour before my car is okay to drive again. I will change the pump, as its only £20 and I will check the carb out. Thank you. :)
Post by: mattlucas on January 10, 2007, 10:38:13 AM
i have 2 spare pumps for a biz were are you ?
Post by: moopster on January 19, 2007, 12:59:45 PM
Hi Matt, thank you for the offer, but i have brought a new one. I installed it the other day and the car is driving like a dream now. Although i need to take it on a long run to make sure. Thank you for you help Chris.
Moop
Post by: Chris Lakin on January 19, 2007, 01:25:35 PM
moop, may i ask when you say a new one, where you got it from?
didnt know they had new ones, is it polish.
im pleased its running well now, :)
Post by: bis13 on January 19, 2007, 05:01:42 PM
just go to any motor factors , they still get them no problems. i did have two but gave one to jorge and ones on bis13 engine.
by the way do you want an engine for your bis (spare) as i need to have a proper clear out now that i have gone all waterless...
Post by: moopster on January 19, 2007, 06:08:52 PM
Hi Chris, I got the pump from the following website:
http://en.fiat500126.de
I have no idea where it was made though.
I would like to have a spare engine, but i live quite far away from you and i'm not sure where i could store it. I'm on a waiting list to rent a garage, but have no idea how long i will have to wait. What condition is it in and how much would you want for it?
Post by: bis13 on January 19, 2007, 10:25:15 PM
ha sorry but i am a tit i meant the engine bit to be adressed to chris , ooopppssss......
Post by: Chris Lakin on January 20, 2007, 01:17:22 AM
no its me, i thouhgt you were talking about a Carb :lol:
i dint read the previous post i just read the thread title
