Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: Chris Lakin on October 31, 2006, 05:57:55 PM
Title: Bores and Pistons?
Post by: Chris Lakin on October 31, 2006, 05:57:55 PM
does anyone know if you can just simply stick 650 bores and pistons into a 500 or 600cc engine? I know with the VW beetles you can do this easily, but is this possible and what else do you need, crankshaft?
i always see these on ebay http://cgi.ebay.co.uk/FIAT-500-126-650cc-PISTON-CYLINDER-SET-BRAND-NEW_W0QQitemZ190044272052QQihZ009QQcategoryZ31352QQrdZ1QQcmdZViewItem and think when the engine does wear out is it possble just to lump these into a 600cc?
Post by: MaLi on November 28, 2006, 11:40:05 AM
Hi!
Unfortunately the 650 cylinders aren't plug&play device for the 600 engine. The hole for the cylinder in 600 is  bit smaller. You just need to rebore the holes and its done. I had it done to my engine.
