For Sale & Wanted => Wanted: => Topic started by: Vin on June 10, 2005, 10:42:11 AM
Hi all,
I am currently in the process of putting my 126 FSM back together after it's return from the paint shop. But to complete I need the following items.
A Windscreen - I took the screens out for the respray, and while inspecting the windscreen I realised it is covered in metal shards embedded in the surface. I since realised these are the 'sparks' from my angle grinder, as I hadn't had the foresight to cover the glass up. Thus the screen is pitted and is even starting to rust :cry: and is basically scrap.
Plastic gutter covers for both sides - Again removed for the respray, but the mastic under them is stubborn and I managed to break them. Again in hindsight I should have warmed them with a haidryer to soften the mastic.
Front lock & Bonnet (boot) release cable - The lock is fine but the cable snapped at the lock end, and I can see no visible way of replacing the cable without replacing the lock assembly as well.
Hope you guys can help :)
Vin
