Fiat 126 Chat => Fiat 126 Chat => Topic started by: Maroon594cc on August 11, 2006, 11:43:53 PM
Hello, I'm a newbie with an early 594cc model on an 'M' plate (1973), in maroon with tan interior, standard and in pretty sound condition for her age. Inherited from my grandparents, the mileage is just 26,000 since new! :)
I was wondering if anyone knows how to go about identifying the build date of these cars? It is chassis no. 4081199 and engine no. 4069433. I tried contacting Fiat head office, but got no response.
According to the registration document, it was first registered on 17/12/73 so unfortunately misses the DVLA's cutoff point for tax exempt status - unless I can prove otherwise, hence the question!
Alas, there appears to be a strange problem whereby the (Magnetti Marelli) ignition coil gets very hot, causing the car to gradually lose power and ultimately conk out altogether until it's cooled off - which can take a good half hour or more. Does anyone know what might be causing this? I've checked the points gap and condensor, even tried fitting an electronic ignition module (which did away with the condensor) and a different (Lucas) coil, all to no avail. The problem somewhat limits the car's useability, so any tips would be appreciated...
Cheers!
sounds like you have a cracker there mate! i have a 1973 aircooled (M Reg too) mine was first registered in the november of that year.
The tax exemption goes by build date as you know, but im 99% sure they didnt make them for sale over here until half way through 73"
however i have an orginal advert from a magazine and the car in the picture is (N reg) :roll: confuses the hell out of me. I think we are just unlucky could have saved ourselves £120. :sad:
ive had a quick think about your coil woes, do you have the heat sheild in place which sits over the exhaust silencer? as the HT leads etc sit right above that, some fall off into the raod and people forget to replace them.
unless you know for sure the coil is getting too hot, i think its sounds more like a carb/fuel prob? there was another bloke who posted today called Steve, he said his early 126 has been cutting out in this hot weather . See below
http://fiat126club.co.uk/forum/viewtopic.php?t=1228
nice to have another early 126 about, i hope you can get to a meet soon with us all.
(http://www.dropshots.com/photos/73614/20060717/111532.jpg)
heres a shot in the dark......nothing to do with that resistor thing that gives full voltage at start up then gradually lowers it?? big coil behind the spare wheel on a bis and fsm aircooled.....justa thought.
welcome by the way...an early 126 is my dream,and that maroon is my fav colour,keep it locked up if im around............ :lol:
Hello matey,sounds like youy coil is too long new.It is over heating and causing a short.Bin it and get a new one,the bambino will be chattering along like a wee mouse chewin paper :D .Have you tried phoning FIAT Uk rather than writing to them.I will probibly see a friend of mine over the next few days who is the service manager of the main dealer here so will ask his advice for you.
Thanks for the replies and compliments - funny to think how it's some people's idea of a dream car! :lol: They are certainly cute to look at and quite a giggle to drive, except on the motorway perhaps :shock:
I'll try getting a new coil and ballast resistor (if it has one - anyone know where it's located on an early model?)
Does the club run any events in the Kent area?
All the best!
Check your voltage as your regulator may be in need of a tweak, if your coil is cooked it may be because the voltage is too high. Should be 12V at tickover, and never much higher than that at higher revs, though a coil can handle a few volts higher.
I don't think early 126s had ballast resistors - I think they were just fitted with the wasted spark coils on the FSMs?
Perhaps you have fitted the wrong coil? (a coil from the later 126 models fitted with a ballast resistor)
The ballast resistor system runs on a lower voltage and if you feed it with 12v it will not last long and overheat.
It's just a thought but worth checking!
OK, thanks for the tips. I've got a couple of days off work so shall hopefully get around to taking a closer look. Are there any specific ways to tweak the regulator (taking this to mean the box fitted on the left of the engine bay)? The car actually has 25,590 miles - possibly the lowest mileage '73 Fiat 126 on the planet? I'll try and put up some pics soon...
Regards
no mate, my 126 has done 16k and im sure there is lower than mine somewhere.
also Jo of the Fiat clubs has only done around 8000 miles.
Coo, that's seriously low mileage! Is that your M-reg one that has just 16,000 Chris?
Some pics at http://uk.pg.photos.yahoo.com/ph/mtjhunt/my_photos
Cheers!
hi maurice, that is fantastic, that colour is superb, im jealous!!!!! yes thats the pic of mine the navy one!!
what size tyres u got on it they look massive??
i'm aiming to do a London to Margate run soon with all the Kent members (we have lots of members in kent) are you up for that?
if ur ever over NW london way pop in!!! im in Uxbridge.
They're just the standard 135R12 tyres, albeit a mix of India GT's out back, a Firestone on o/s/f (which does look admittedly taller in profile, but I think it's an illusion!) and a weird el-cheapo (Polish?) make on the n/s/f. The spare's also a Firestone, but has a puncture...hmm, a bit like my daily driver car :oops:
With the car's current reliability issue with the coil overheating, I don't think it'd be up for the full London-Margate run to be honest, but I'm sure it could be persuaded to reach Margate...
Cheers!
