Fiat 126 Chat => Fiat 126 Chat => Topic started by: UKCat on August 01, 2006, 02:01:35 AM
Title: My New 126
Post by: UKCat on August 01, 2006, 02:01:35 AM
After much admiration for the last few weeks I've finally bought a 126!
Details here:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ih=015&item=250012728534
I saw it when it was on ebay for only 58 minutes and bought it immediately.
Cost me the princely sum of £300 with 12mths MOT and 6 mths tax, what do you think?
Only problem is its about 110 miles from me so hoping to collect it this weekend.
What should I check/do when I get it back to make sure it's a real little cracker?
UKCAT
Title: My New 126
Post by: paul harbinson. on August 01, 2006, 07:37:43 AM
Well done there it's an absolute clinker :wink:
Title: My New 126
Post by: Chris Lakin on August 07, 2006, 10:12:31 PM
hi UKcat im in Middlesex, if you are picking the car up and you are near me your are welcome to pop in for a cuppa and a chat and a look at my 126's. Im in uxbridge
Title: My New 126
Post by: UKCat on August 08, 2006, 01:16:28 AM
Thanks for the offer Chris.
I got the National Express from Leicester yesterday (Sunday) at 7.45am to Heathrow Airport, it arrived early at 10am.
The chap I bought from was from Hounslow and met me at the BP petrol station in Heathrow and he drove me with his wife in convoy to a nearby garden centre where we did the paperwork and she waved her car goodbye.....
I planned to drive back via 'A' roads which according to RAC website would have taken 2hrs 35mins, Barry the chap I bought off said it would be plenty good for the motorway so I took his advice and drove at 60mph on the M25 and M1 and got home in just 1hr 40mins.
I was impressed that the little fella was so happy at 60mph and I had the overtake a few lorries going up to 70mph about a dozen times and it still felt like it had more to offer speed wise.
Body is tidy, mainly cosmetic rust and I was given a couple of extras (speakers, mdf parcel shelf and a roll of black audio box fabric + the original owners manual).
Tyres and exhaust are good, 12 mths mot and 6 mths tax for £300 what a bargain. Can't wait for the weekend to go for a drive as I cannot park at work so ride a 100cc Peugeot Scooter and the 126 will be it's replacement.
Best bit of the day is when I came home and my 2 yr old came out to see the car (play in it) and pointed at it and said 'ooohh - Baby Car'
And baby car is what my wife and I shall now call it!
Only thing I noticed is that under accelaration it seems to have a 'metallic' engine rattle, sounds like a fan catching a guard or the exhaust against the body, is this a common thing? Also idle speed seems a little low, the car sort of rocks side to side and is close to cutting out, so I must adjust that too!
UKCat
Title: My New 126
Post by: paul harbinson. on August 08, 2006, 07:38:15 AM
It's "pinking" mate or it's proper nane detonation.You need to retard your ignition slightly.A lot of it is to do with modern fuels.
Title: My New 126
Post by: dajwid on August 08, 2006, 09:21:36 AM
Great, well done!
 I still can't pick up my UK car for 3 weeks, when I move. it is still sitting in the guys garden.
Title: My New 126
Post by: Chris Lakin on August 08, 2006, 09:40:51 AM
see i thought i had pinking,  nasty little rattle when accelerating especialy up hills, i put diff oil viscosity in and the rattle stoped. Come to think of it though i had adjusted the timing before the oil change. do timing chains rattle? My Gearbox makes a rattling sound when in    4th if i hold the gear knob itstops rattling. could be that?
Title: My New 126
Post by: 126dave on August 08, 2006, 05:08:03 PM
bit of confusion on here sometimes methinks,'timing' is ignition timing,points etc,however some refer to 'timing' as the RPM at 'tickover' or 'ideling'slowing the timing therfore has no real meaning...............
yes chris,the timing chains will rattle after high milage or zero oilchange sevice etc...........if thicker oil stopped your rattle chris,id be a worried man............................
Title: My New 126
Post by: Chris Lakin on August 08, 2006, 06:19:32 PM
the car has only done 15k so no reason to be worried man.
Title: My New 126
Post by: bis13 on August 09, 2006, 09:26:40 PM
chris that rattle you talk about is the linkage to the gearbox mate i have the same(had).if you hold the gearstick it stops....the metalic rattle previously described is the exhaust possibly either starting to loosen (bolts) on the brackets or cracked bracket mountings on the box itself , i have had this happen as well...
Title: My New 126
Post by: Chris Lakin on August 10, 2006, 10:27:06 AM
yes mate exactly that, when i hold the knob it stops, it only happens in forth when im not going fast enough. How did you sort it?
Title: My New 126
Post by: neil 126 on August 10, 2006, 10:37:41 PM
hi chris, this rattling you hear in 4th, is it the actual geer stick hitting the housing? do the gears all engage with out popng out?
you may find that that they are not properly selecting,in otherwords the gears may just only be catching. you may need to reposision the selecter. an amount of adjustment is available if you adjust the gear lever linkage at the central consul between the seets, you will need to take the carpets up and loosen two 13mm bolts on the central consol to reposision the gear lever linkage.
hope this helps.
Title: My New 126
Post by: Chris Lakin on August 10, 2006, 11:37:59 PM
you are the first person who has explained how to adjust this linkage, ive been looking at the linkage under the car which looks in good condition.
my first gear just doesnt work at all, the car shudders as i pull away :( 2nd, 3rd,4th and reverse all ok.
i might pull the carpets up tomorow, ive looked before for these 13mm      bolts but couldnt see them down there.
thanks Neil
