Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: Neville Minuti on May 12, 2019, 07:44:12 PM
Hi guys
I have a 126 fsm air cooled yom 1987.
I have been noticing, after I switch off the engine, a smell petrol. However upon start up & running there is no smell. I am unable to find any leaked petrol, though sometimes find the plate under the carb with some fuel.
Any suggestions what this could be? I use unleaded petrol 95RON with lead substitute.
Many thanks
neville
First check would be to check the float in the carburettor and make sure that it is not punctured, then check the float needle valve and float are in tolerance.
Hi
Thanks for yr feedback. The float I have replcaed, therefore I will look into the 2nd suggestion.
Thanks.
How old are your fuel hoses? they might be worn or not fitted properly?
No need for lead substitute btw, 98 would be better anyway.
Sent from my HUAWEI VNS-L31 using Tapatalk
Your right there. Main Fuel pump hose which connects to carb is a favourite.
