Welcome to the CLUB126UK Forum => Introduce Yourself => Topic started by: TonyC on February 13, 2018, 09:12:25 PM
Good evening everyone.
I have recently bought a D reg 126p and, according to the V5, it is a 'Brown' model. Is there much significance to this?
The air intake/cooler housing with the alternator attached to it was on the back seat of the car when I bought it, and shows extensive signs of having rusted through and then been repaired in a DIY fashion, to the point where I think it would be better to replace.
I believe the car has done 124000 miles, although the odometer shows 24000.
Can anyone help with where to get a new/used air cooler housing? Or potentially a new entire engine?
I intend to restore the car as much as I can to original spec, or to at least look original.
I have found the Ricambi website for spares, could anyone recommend any others for spares please?
Thanks very much.
Tony.
You'll find a few things on eBay (LP Garage operates from there)
The only other UK shop is Ricambio.co.uk, but they're pretty expensive.
You'll find a big selection at cheaper prices from shops on the continent. Here are the ones I have found so far:
126fan
http://www.126fan.sk/eshop/index.php?main_page=index...
Axel Gerstl
https://webshop.fiat500126.com/
Fiat Fischer
http://www.fiat500-fischer.de
Motozbyt
http://www.motozbyt.net/22-126p
http://www.motozbyt.net/32-126p-bis
F. D. Ricambi
https://www.fiat126ricambi.com
Günter Markoff
http://webshop.fi500.com/en/Fiat-126
Regmot
http://sklep.regmot.com.pl/products/wybor-wg-marki-samochodu/fiat/fiat-126p-fl-el-std-bis,2,13908
Allegro.pl is the cheapest, but you'll need Google Translate and a few extra minutes to find your way about.
Failing that, just let us know what you're after
Hi Tony , good luck with the car . I have a couple of engines and loads of parts. :)
Hi guys, thanks for your replies.
I think I am best to go for a new (used) engine. Then I can use what came with the car as spares if need be or re-build it in the future.
So, has anyone got a 652cc air-cooled engine in decent nick that I can buy?
Thanks.
