Fiat 126 Chat => Fiat 126 Chat => Topic started by: Michal on August 19, 2017, 10:38:42 PM
Title: Fiat 126 registration
Post by: Michal on August 19, 2017, 10:38:42 PM
Hi i bought a fiat 126 in poland but it has no headrests in the front or in the back ot also has old style seat belts which dont retract back and are loose i dont know if it will pass a mot or will i need to change it
Thanks in advance
Title: Re: Fiat 126 registration
Post by: michaelodonnell500 on August 19, 2017, 10:41:39 PM
What year is it?
Post by: Michal on August 19, 2017, 11:14:45 PM
86
Post by: Michal on August 19, 2017, 11:30:03 PM
But its a polish import
Post by: Xylaquin on August 20, 2017, 02:07:17 AM
126s produced before April 81 only need belts in the front that restrain the upper part of the body,
126s produced between April 81 and April 87 need a 3 point belt in the front.
126s produced after April 87 need a 3 point belt in the front and at least lap-belts in the rear.
Head restraints don't seem to appear on the MOT manual. I wouldn't worry about it, I have a 88 UK model with no head restraints and it passes.
Post by: Michal on August 20, 2017, 07:20:13 AM
Thanks but do the seatbelts need to go back to the correct place like in the new cars as i have the old ones witch you need to hang up
Post by: Gadge on August 20, 2017, 07:39:53 AM
I'm not 100% sure but I think you will be ok with front and rear lap belts however it wouldn't cost the earth to fit retractable ones.
Post by: Michal on August 20, 2017, 09:16:42 AM
Ok thanks
Post by: Xylaquin on August 20, 2017, 10:34:53 AM
According to the MOT manual, they don't need to.
Post by: Michal on August 20, 2017, 10:40:38 AM
Ok thanks
Post by: Michal on August 20, 2017, 01:09:09 PM
I also have another wuestion as i only have one wing mirror on the left will it pass a mot or do i need to have a right mirror
Post by: Xylaquin on August 20, 2017, 01:53:12 PM
I believe you do need both mirrors. This (https://www.gov.uk/government/uploads/system/uploads/attachment_data/file/408211/Information_Sheet_Mirrors.pdf) seems to suggest you technically only need a passenger side mirror if your internal mirror gives you "an adequate view". But for the sake of the MOT, your visibility and the design of the car, I'd buy another mirror!
Post by: Michal on August 20, 2017, 05:09:44 PM
Yeah i think i will buy another mirror howether i would rather keep it as original as i can
Post by: michaelodonnell500 on August 26, 2017, 07:30:20 AM
I would try to keep just the one mirror to keep it original,  but if it's LHD the mirror won't be much use driving in the UK! Although 2 mirrors weren't standard when the car was sold a lot of owners had them added when it became more common to have a set.
Sent from my D5803 using Tapatalk
