For Sale & Wanted => Wanted: => Topic started by: 126dave on June 25, 2006, 02:23:53 PM
im looking for a cinquecento space saver spare wheel..... :cool:
i got a seicento one for mine of ebay, it is almost identical to the Bis wheels. just a thicker bolt hole, got it to match the cinquecento alloys on my bis uses the same size tyre as the bis, just has a red wheel with a yellow 80 on it.
when i got the cinquecento wheels i had the bolts with them but they are a different thread to the 126 bolts so in the end i am using them.
ah bruce, i thought they smaller than that!! maybe i'll just stick with what iv got,was tring to cut some weght!!
dave best space saver ever ! 1 x AA card (or similar) get a flat , tow it home.....
the AA will come out to fix a flat, but you must have a spare i doubt they will tow you home if you have no spare without charge. get soem run flat tyres, they do work although i am am unsure if they do any that will fit the 126, or to save wieght try blowing your tyre up with helium :)
heheheheh,jersey so small i can walk home to get the spare............thanks guys! :lol:
