Fiat 126 Chat => Your Restorations => Topic started by: 1300ot on August 25, 2016, 07:15:12 PM
Hello.
I've just purchased an MCA coupe that I will be restoring so I'll add a few photos as I progress. I could do with a little advice on the wheels/hubs if possible though.
It has the later 126 hubs and brakes fitted already, however I would like to fit some early wheels with the wider bolt pattern. Is it possible to do the 'reverse' of the normal 500/126 hub conversion?
I'm guessing I'd need to replace the hubs/stub axle and complete brake drum units for the early ones?
Or more simply, could an adaptor be made up to fit?
Thanks in advance :)
I believe you can buy adapter plates. I have seen them used on 500 disc brake conversions. I presume you can purchase the adapters.
https://www.fiat500ricambi.com/beheer/fotos2/RS1069_groot.jpg?v=1472162926
An alternative is to use rear drums if they fit your front
https://www.fiat500ricambi.com/beheer/fotos2/RS1017_groot.jpg?v=1472163253
I have got a spare pair of adapter plates if you are going down that route :)
Thanks Ralph. Rusty's Uncle - I have sent you a pm
good luck with it
looks like its been modified over the years, i believe it was built around a early 126 so would of had the older style of brakes since it had those nice wheels
Thanks for the advice and help - in particular Rusty's Uncle - thanks for the bits!
I've attached some photos of a stripped down MCA.......
Will be going back together soon.
Chassis is back and powdercoated.
If ever anyone needs some classic car parts blasted/powdercoated I can highly recommend Maldon Shotblasting and Powdercoating in Essex.....
wow that looks amazing, is the body going to be the original turquoise colour?
Thanks very much to amam for supplying two badges! I have sent some good karma your way. Yes, I've gone for turquoise.......
Wow great work there :thumbup It is starting to come together.
