Fiat 126 Chat => Fiat 126 Chat => Topic started by: Chris Lakin on June 15, 2006, 08:25:00 PM
Any suggestions on best approach to take to this rust? as its even worse than the pics depict!
(http://www.dropshots.com/photos/73614/20060615/b_120622.jpg)
(http://www.dropshots.com/photos/73614/20060615/b_120624.jpg)
(http://www.dropshots.com/photos/73614/20060615/b_120630.jpg)
(http://www.dropshots.com/photos/73614/20060615/b_120626.jpg)
(http://www.dropshots.com/photos/73614/20060615/b_120631.jpg)
(http://www.dropshots.com/photos/73614/20060615/b_120635.jpg)
(http://www.dropshots.com/photos/73614/20060615/b_120633.jpg)
http://www.dropshots.com/day.php?userid=73614&cdate=20060615
new panels are essential with that degree of severity
New panels I think Chris!
It's not worth patching up this type of corrosion, it will only come back!
Is that the 73 Fiat 126 you picked up the other day?
hi guys, thanks for your input, yes m8 this is the one i got the other day looks pretty from pics taken at a distance, but some nasty rust lurking throughout the car.
:sad: new panels it is then...eventualy
Here is the old veng list, it may help you decide what panels will be required. How are the sills and inner sills?
(http://fiat126clubuk.freepgs.com/vengpanels.jpg)
click image to enlarge
looks like a full resto job, :shock:
i have a genuine fiat front panel and wing for sale if its any use to you. :wink:
thats not bad cut it all out and fill it with papier mache lashings of glue and repaint it . then sell it on e bay to some un warry sod .
yer im thinking bit of aluminium mesh and isopon 38, rust treated with hammerties Kurust Gel, left to simmer for 2 hours, then primed with Davids zinc 182 before and after filler, with primer filler over top to glaze with top coat of paint, rubed down gently to remove imperfections in the texture with fine wetn dry, and buffed with a cutting compound, served with a sprinkle of chives and a honey dressing.
only kidding, :lol: :lol: im gona cut the rust, package it up and send it back to the Russians, and get some proper fresh metal in!! last time it will mess with me!!! :D
:smt067
Here Chris thats superficial for 73'
Good luck with the work Chris!
I have done a few cars a lot worse than this. The secret is to do it in stages not all at once. If you cannot obtain any of the panels new perhaps you could salvage panels from another shell, does the Bis have the same panels?
Chris,
I have a pair of Genuine Fiat wings for the early cars (they wouldn't fit my FSM or a BIS) that you can have for nothing (would be to a good cause after all :D )
I'll PM you.
Vin
I,d suggest getting it blasted and primed to be honest if its that bad it will be hard to see the severity of the rust till its laid bare, as it looks like its been repainted more than once.....
then make a panel list then start at the front and work your way bto the back :D
hi guys, thanks for the help, it is a job and a half but at my brothers at present hes cleaed out his garage and giving me his MIG welder to use as well as some lessons.
Vin thats good of you m8, will chat to you about those, was good to see your pandas last weekend at autoitalia.
i was thining about cutting the spare wheel well out of a scrapsped BIS shell and welding that in, is that feasible? or shoddy?
Thanks again
Chris :D
Seen much worse. don't worry. sure you will get is sorted.
Shame my shell has gone now, front end was Ok.
If you can, use LMC Hadrian panels if no genuine available, as these are the best fit. Veng are really poor and need lots of fettling, trust me on that one mate!
even the hadrian panels are a pain,front wings in particular.........my advice would be leave it alone until you have all the panels chris,many a car gone to the crusher half restored.........then if you do run out of time/money its a complete car and spares your selling.
and also,spend some time and effort sourcing correct fiat panels,my local supplier managed a front panel for £80.00.and original stuff does crop up on ebay.....you also need to find out the build sequence ideally..........for instance,you cannot really replace front wings without the little panels that go above them (hadrian cannot supply those).
to paraphrase some one elses signing off....been there,learnt the hard way
I would go along with Dave on this, source the panels first! It will also give you time to get to grips with your mig welding. There are usually courses at local colleges, perhaps you may have similar course in your area?
