Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: craigdiver on June 30, 2016, 05:38:06 PM
Title: Replace side window glass - ELX
Post by: craigdiver on June 30, 2016, 05:38:06 PM
Hi folks,
Can anyone give me some guidance on swapping the side window on my Fiat 126 ELX (the current glass has a score right down it where it has been rubbing on something)
I would guess at;
1) remove winder handle & door card
2) remove winder mechanism
??3) remove trim at base of window
4) rotate and remove glass up through bottom of window frame?
Photo of window;
(http://i98.photobucket.com/albums/l246/craigdiver/Mobile%20Uploads/image_5.jpeg)
Title: Re: Replace side window glass - ELX
Post by: craigdiver on July 06, 2016, 09:04:27 PM
Managed to get the information from Lucas (LP garage);
This model its easy just remove door panel and undo all the 10mm spanner bolts, the glass will go easy.
Hope this helps someone else.
Post by: Ricksy1121 on August 25, 2019, 10:46:22 AM
Anyone know if this glass can be used to replace the the other type with the main and 1/4 glass. Can it be retro fitted and what changes would be needed
