Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: amam on May 21, 2016, 03:49:05 PM
silly question i know but where is reverse gear on a 126? :$
been checking everything on my MCA which is based on a 1979 126
anyway can get all 4 gears but struggling to find reverse, if the gear knob is original it says reverse is next to 4th, do i have to push the gear stick down or something as i keep just engaging 4th gear whatever i do
Push the gear stick down and move back towards 4th gear, if it struggles to engage a trick you can try is to run it through all the other gears first and it should then be okay. Unless it is broken...
well i cant seem to find reverse, i know where it should be now but it engages 4th instead.....
according to the haynes manual i need to adjust the gearshift linkage if its difficult to engage any of the gears, will have a go
There are some rubber bushes that you can fit, very cheap but make a big difference if you are having difficulty finding the right gear...
Hello
I am new to this forum
fiat 126p is known to me because I studied at these beautiful cars to car mechanic and I know them very well.
My advice is to start with teeth make sure the two parts are in some
1 connection gear box. It is not loose and in one piece
2 Mount gear box are in one piece and regulation is well.
adds pictures like these parts they look
sorry for my spelling.
thanks
I'm sorry but I can not add pictures
but gives the address for pictures
connector gear box
https://www.google.co.uk/search?q=fiat+126p+poduszka+skrzyni+biegow+zdjecia&espv=2&biw=1280&bih=709&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwjWlLnJouzMAhVJJcAKHe3VDZgQsAQIHQ#tbm=isch&q=fiat+126p+lacznik+skrzyni+biegow+zdjecia&imgrc=FEnRVjXSXHStuM%3A
[/size]Gearbox[/color][/size] Mounts [/color]
[/size]https://www.google.co.uk/search?q=fiat+126p+poduszka+skrzyni+biegow+zdjecia&espv=2&biw=1280&bih=709&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwjWlLnJouzMAhVJJcAKHe3VDZgQsAQIHQ#imgrc=_JchBNCyFSoZCM%3A[/color]
