For Sale & Wanted => Wanted: => Topic started by: DannyPancho on December 08, 2015, 01:48:00 PM
Title: Fiat 126P RHD
Post by: DannyPancho on December 08, 2015, 01:48:00 PM
Hi! im in desparate need of finding a 126P in right hand drive! No matter what i do, i cant find one anywhere for the money i have! if anyone knows of one or has one which is in good working order (doesnt have to be great) (as long as the thing is drivable then im willing to think about it!) as it stands a LHD in my oppinion isnt the best for the UK but RHD is seemingly hard to come across... :cry:
thanks in advance
Title: Re: Fiat 126P RHD
Post by: Xylaquin on December 08, 2015, 05:31:40 PM
How much money do you have?
I don't think there is such a thing as a RHD 126p, the p stands for Polski, models for the European market up until 2000.
The latest UK model would be a BIS.
Post by: DannyPancho on December 08, 2015, 06:49:55 PM
True! Unless all RHD 126's that arent the Bis are 'Browns' then i dont stand much chance because theyre meant to be quite rare! As its stands, i would spend about £1,300 as a limit  ;D
Post by: Gadge on December 08, 2015, 07:18:44 PM
You'll be very lucky if you can pick up a decent aircooled 126 for £1300. MOTed rhd cars are starting around £2000 - bis versions are cheaper but less desirable. Polish imported 126 (lhd) could be had for £1500 for a decent drivable one but you'll need to get it registered. One that are registered will be more. I'm afraid prices are on the up
Post by: DannyPancho on December 08, 2015, 07:34:43 PM
Thats what i was dreading  :$ i guess ill have to leep saving or stuff it and gor for a LHD! Ill just keep scrolling the classifieds! Cheers  :P
Post by: 1973/126 on December 09, 2015, 09:52:34 AM
 Go for a left hooker, just make sure you check everywhere for rust. Those later models are even more rust prone.
 There are quiet few on Gumtree at the moment and some that look half decent for under a grand.
 They are of course still on Polish plates, but this will give you a bit of leverage on the price and the registration process is not that difficult.
 As the guys said on the road rhd air cooled cars are more like 2k at the moment, unless you are prepared to take on a project.
 BTW most of the air cooleds including rhd after cca 1980 were built in Poland so they are technically a Polski.
Post by: DannyPancho on December 09, 2015, 04:39:42 PM
I have taken your advice and gone onto Gumtree, its fantastic! i think i will go for a LHD because theyre so much cheaper :P do you have any experience of driving a LHD in the UK? I believe it would be fine but others say that it could be difficult... any thoughts? Cheers!! :D
Post by: Xylaquin on December 10, 2015, 01:45:18 AM
I've never done it, but I imagine the only thing would be you're used to reaching out for the gearstick with your left hand instead of your right.
Oh and going through drive-thrus will be fun ::)
I've sent you a PM!
Post by: 1973/126 on December 10, 2015, 08:11:27 AM
 With a small car like a 126 lhd isn`t really a problem. The biggest issue is when you have to overtake and you haven`t got a passenger in the car to look for you :)
 I also find the pedals work better for me in a left hooker.
Post by: DannyPancho on December 10, 2015, 07:45:27 PM
haha yeah thats true, its only 1.3 metres wide??  :P how so? is it becasue of the wheel arches in the footwell or something like that?
Post by: drcdb15 on December 11, 2015, 10:54:14 PM
Most cars made outside the UK and Japan are primarily for a left-hand drive market. When a right-hand drive version is made, pretty much all of the front occupant's area is simply mirror-imaged across from left to right. Hence all the geometry of the design is perfectly replicated and looks the same, just 'back to front'.
However, the foot pedals cannot be treated like this or the usual L-R arrangement of clutch/accelerator/brake would be reversed. The pedal assembly has to be carried over unchanged - complete with its own geometry - and somehow fitted into the available space on the other side.
Most cars are pretty tight for space in the footwells, especially if there's a transmission tunnel, or in a short wheel base car where the wheel intrudes into the footwell. The original left-had drive pedal assembly is usually carefully designed for an optimum fit into the left hand well. Almost by definition, then, if you now transplant that arrangement onto the other side, without mirroring it, the fit will be non-optimal. Where your left foot, for example, had plenty of room by the inside of the front wing, it is now squeezed up against the centre console - and so on.
If you look at the exact components of the pedal controls in left and right hand drive versions, it is very typical to see some very elegant design on the LHD one, but the RHD one is a complete hotch potch of extra extension bits and secondary levers and dog-leg bends etc to try to get the fit into some sort of usable position.
There is a good example of this on the 126, with the throttle pedal. On the LHD it is right next to the centre tunnel, and the cable link is nice and neat. On the RHD version, the pedal is now on the outside edge of the car, and Fiat have used the long rod rotating in the tube that's bolted to the floor to carry the pedal's movement across the footwell to the centre tunnel, in an area subject to dampness from a wet British driver's foot. So not only is the mechanical arrangement poor, it is placed in a region that is wet, dirty and impossible to lubricate - which is why it is a classic seizure point on British cars that our Italian and Polish cousins have never had the pleasure of experiencing!
Ladislav finds the LHD pedals easier to use for the simple reason that they are properly designed, whilst the RHD drivers have to put up with what is essentially a production botch.
Post by: drcdb15 on December 11, 2015, 11:10:44 PM
Another more extreme example of this can be found on another Fiat, the Idea MPV. A friend of mine had one of these, and the ABS pump failed. Simple job, just get a recon one and swap it over....
Not so. After months of searching, and two garages returning the car having given up on it, another friend sourced one in a scrappy in Germany of all places. Oh come on, I said, how can it be that rare, it's only an ABS pump, are you telling me Fiat made a special pump JUST for the UK market, and JUST for that one model (most Idea parts come from the Punto, it seems).
Well it turned out the answer is "yes" - in converting the originally LHD Idea to RHD for the UK, Fiat faced an insurmountable problem - if they fitted a RHD pedal box, they couldn't leave the standard ABS pump where it was on the other side of the bulkhead. But if they kept the pump, they couldn't fit a RHD pedal box...
On the LHD car, of course, the pedal box and ABS pumps were on opposite sides of the car. In converting from LHD to RHD you don't need to move anything in the engine bay except the steering mechanicals.
They couldn't do anything about the pedal box, that HAD to be in the usual RHD position, so they had no choice but to do something about the pump. They resolved this by placing the ABS pump in a slightly different location, but one where the standard pump wouldn't fit. Obviously they didn't find any other option, and they ended up making a bespoke pump just for that one model and just for the RHD markets... oops!!
It is no coincidence that the Idea was only sold in the UK for about 3 years, and was something of a commercial failure.
Post by: DannyPancho on December 12, 2015, 01:00:05 PM
wow :o good god that was useful! okay ill take all that into account when looking; sounds like a LHD is the way to go for just about every reason i can think of now! thankyou very much  :D
Post by: alastairq on December 12, 2015, 02:31:38 PM
LHD should not be an issue for a driver. Unless one is the sort of driver who is less than unhappy driving  less than 2 seconds behind the vehicle in front?
Overtaking merely involves thoughtful positioning to obtain a decent view ahead.
However, LHD can confuse other road users, as the driver of a LHD vehicle may well adopt a slightly different position at junctions, etc, in order to see clearly.
[I have often driven LHD military Landrovers....a bit of a pain when dealing with roundabouts, since they don't have windows behind the doors. So, when one considers at most UK roundabouts, one presents oneself  at an angle to the road markings prior to entering, doing likewise with the Landrover completely masks ones view to the right!! One ends up, effectively, pointing in a an entirely different direction to everyone else in order to see to the right!!  Good fun on motorways, however, as when being overtaken, there is, apparently, no driver!!]
I have recently purchased a 126 bis for the princely sum of £250.
It runs, it drives, it needs some bodywork attention, but seems essentially sound.  It needs its [back, especially] brakes re-commissioning...then engine will need a service.....for the moment...and, given the weather, all I have really done is de-seize the throttle pedal.
Oh, and put a nice big order into 126fan shop, for a big box full of panels and stuff.   Cheaper than patching and so on.   :)
Post by: mintex on December 12, 2015, 03:02:59 PM
Dont dismiss a rhd model if it shows up though  :D
Post by: DannyPancho on December 12, 2015, 03:37:49 PM
yeah, no im not one to drive up the exhaust of the car in front! although a 126 may be small enough to fit... i cant imagine it being too much of a problem overtaking because you tend to overtake after approaching a stopped vehicle (bus for example) and by that point, you will have been able to see ahead to know if anything is coming!
(With the ditsy engine i wouldnt be expecting to overtake anything moving)   :P
and yes! a RHD will always have a place reserved in my heart   ;D
thanks to all for your help!  :D
Post by: drcdb15 on December 12, 2015, 07:43:48 PM
Is it just me, or do I smell a business opportunity opening up here ....  ?
Europe awash with LHD 126s going for a song, UK in the grip of Classic Car Fever, where retired old gits like me, with more money than sense, can't wait to re-live their misspent youth by buying the cars they always dreamed about as a teenager but could never afford ? (It's certainly true in my case, I always wanted a Scimitar and a Lotus Super 7 - but my first car was a 500 Giardiniera. Now I'm retired I'm on my third Scimitar, and if I look sideways and squint a bit, I can *almost* see the Super 7 re-born in Ladislav's CC Zero ... )
But I digress.
Since RHD 126s are going for multiple thousands, whilst LHDs can be had for a few hundreds, what exactly is involved in converting LHD to RHD? Panels and parts are readily available these days. Welding expertise the same.
Both full scale conversions and after-market kits should be well within the abilities of some of our membership. After the success of the calendar I propose Chris H as Commercial Director, and Gadge as "Senior" Technical Director  :P
The proceeds from sales of these products can then be used to buy up all the unfinished bike-engined projects and restore the cars to their former RHD glory, then to be sold on for even greater profit and replenishing the global 126 stock into the bargain.
Now, is that a cunning plan, or what ??
[Discuss]
Post by: drcdb15 on December 12, 2015, 07:52:14 PM
I should of course have said "clutch/brake/accelerator". Apologies to any confused learner drivers who read that and just drove through a wall...
Post by: alastairq on December 12, 2015, 11:15:49 PM
Many decades ago, I took a trip to Southport, to see CArCraft..with a view to buying a CC Zero kit. I remember I test-drove their demonstrator. What a hoot to drive!..
I have never been enamoured of the typically British view of 'big engines are best'...and something with only 600-odd ccs is but a joke. The Zero drove and handled like the actual, speed-hill-climb thoroughbred it was....its race car heritage shone through..it handled just like a top dog  gokart....actually going exactly where I wanted it to go.
Power, I think, was about 40 brake..the engine ran a SU carb.
The standard of build was exceptional [rare at the time, especially considering it wasn't something like a fake snake!]...it even retained the FIAT heater system.  Weather protection was top notch too.
Sadly, there was a bit too much lead time for delivery...and life got in my way  once more.....so I didn't get to build one [got my deposit returned too....it was a bit of both sides really. I was quite deeply into trialling, and the Zero lacked one essential feature....ground clearance!]
Post by: DannyPancho on December 14, 2015, 10:02:37 AM
that sounds like a good idea to me - as long as one has the skill and means to do it! As an 18y/o myself ive got that exact problem, a whole heap of things i want to do, but no money and time to do it - hence why i cant afford to buy a half decent rhd and do it up.
as for the bike engine conversions, when done well can be fantastic but for the ones who have failed, i cant say the same - althoug there should now probably be a section for 'failed bike engine conversions for sale' so anyone wanting to do it could re use someones failed attempt instead of wrecking yet another... hmm...
Post by: Pete126 on December 14, 2015, 04:32:42 PM
There already is a thread about unfinished bike engine conversions ;D
http://club126uk.co.uk/forum/index.php?topic=9392.45
Post by: DannyPancho on December 14, 2015, 10:05:30 PM
Well i stand corrected! Glad thats sorted  :P ;D
Post by: Gadge on December 15, 2015, 01:10:14 PM
I started that thread really to highlight just how many 126's were being lost in this quest to fit hugely powerful engines into them. I found that it wasn't just an isolated case - it's happening all the time! but alas it's quite a challenging (and not to mention time consuming and money absorbing) thing that people end up just abandoning the project. It's startling just how many people have tried and failed at it - aspecaily in the case of the BIS as they are dirt cheap. Some people are even trying car engines now :(
Post by: DannyPancho on December 15, 2015, 09:52:19 PM
its a shame this is happening - i have to admit i was toying with the idea myself, as im an engineering student, but the car is meant to be kept as it was made, the under powered feel im sure would put a grin on ones face - i just need to buy one myself to find out!  ::)
i hope they sell on the engines they remove so someone can restore a 126 to its former glory
Post by: Bambino126 on December 16, 2015, 01:30:46 PM
Danny, there is a RHD Aircooled 126 on the Autotrader right now.
Post by: dajwid on December 16, 2015, 01:43:07 PM
But you can just drop a bike engine straight into one of those 😀😀😀😆
Post by: DannyPancho on December 16, 2015, 01:56:00 PM
It is still tempting  :P
Ive found the one youre on about! Looks pretty good! Just need a lil more money :P hopefully itll stay for a while!
