Author Topic: clean engine  (Read 6727 times)
delmar
clean engine
« on: April 10, 2012, 07:37:21 PM »
first job is to clean my engine before the re-build, here it is before and after .... and its not painted !
« Last Edit: April 10, 2012, 08:07:54 PM by delmar »
Hazey-n-Marc
  • It's Hazey's car, she does let me fix it sometimes
Re: clean engine
« Reply #1 on: April 10, 2012, 08:01:26 PM »
Where?
delmar
Re: clean engine
« Reply #2 on: April 10, 2012, 08:08:45 PM »
sorry was trying to make pics bigger...   got them on now... ;D
Hazey-n-Marc
Re: clean engine
« Reply #3 on: April 10, 2012, 08:10:02 PM »
Hmmmmn, shiny  :D
Amateb8
Re: clean engine
« Reply #4 on: April 10, 2012, 08:24:07 PM »
Wow. It looks new. What did you use to clean it with?
delmar
Re: clean engine
« Reply #5 on: April 10, 2012, 09:14:54 PM »
vapour blasting, also known as aqua blasting, its a mixture of fine glass beads and water, forced by compressed air, its done in a cabinet like a grit blaster...  but with much better results...
ypsilon_lancar
Re: clean engine
« Reply #6 on: April 10, 2012, 09:59:16 PM »
I just cleaned mine and it looks like your before picture now!! You dont want to see my before picture!!!!  :o
delmar
Re: clean engine
« Reply #7 on: April 10, 2012, 11:22:17 PM »
hi ypsilon .....  have you got your engine stripped ?  or are you just giving it a clean under the hood
ypsilon_lancar
Re: clean engine
« Reply #8 on: April 10, 2012, 11:28:09 PM »
I stripped the engine down completelly to give the internals a good decoke and to change all the gaskets. It was leaking oil all over and baking it to the engine. I cleaned most of it with gunk and parafin before sandblasting the tinware. I then repainted all the tinware and reassembled it. Its now sat in the boot of my other car waiting for fitting this weekend! I have done it just as a tidy up before I take it out again this summer for a tune up. Im going with the Panda 30 head fingers crossed!
delmar
Re: clean engine
« Reply #9 on: April 10, 2012, 11:39:53 PM »
ypsilon ....... im ready to buy the bits  for mine, i cant decide wether to go all the way and have the crank balanced, flywheel lightened and balanced, port the head (is panda 30 head the way to go ?)
 and fit a twin choke weber 40, or just get new shells and main bearings and build it up standard,
 if i just do it standard for now i would buy another engine and make it into a full blown screamer (WELL A BIT OF A WHISLER !)
ypsilon_lancar
Re: clean engine
« Reply #10 on: April 10, 2012, 11:45:41 PM »
The Panda 30 head is a good mod to go for bit mine is an A/C model (I also have the advantage of going over to Italy every year where the Panda 30 is a bit more common place and easier to find in the scrap yard). With it being so easy to take the engine in and out etc I have been doing it in stages. What you have said though all sounds good. Are you doing the work yourself?
delmar
Re: clean engine
« Reply #11 on: April 11, 2012, 12:24:09 AM »
yes doing the work myself, i have a mate whos handy with the spanners, and have a friend with an engineering shop so makes things easier, i used to tune minis when i was a bit younger !
delmar
Re: clean engine
« Reply #12 on: April 11, 2012, 12:26:08 AM »
here it is
delmar
Re: clean engine
« Reply #13 on: April 11, 2012, 12:30:07 AM »
engine
Da Londo
  • It's not the carb size that matters, it's the jet
    • Fiat 126 blog
Re: clean engine
« Reply #14 on: May 05, 2012, 09:29:56 AM »
Nice color on the car, and engine is as new.
