Author Topic: Engine won’t turn over  (Read 241 times)
Iansmi1972
« on: June 12, 2021, 06:51:00 PM »
Hi guys apologies if this has been asked previously but I drove my fiat 126 air cooled engine two days ago and went a treat, tried to start today and nothing, won’t even turn over
Any ideas on what the problem is
I have recharged the battery but still nothing
Minijohn
Re: Engine won’t turn over
« Reply #1 on: June 12, 2021, 10:19:02 PM »
When you turn the key to the 1st position do oil & ignition warning lights come on?
If yes, what happens to those lights when you turn the key to the 2nd position? (I'm assuming it has a key starter)
« Reply #2 on: June 12, 2021, 10:20:40 PM »
If the headlights are working and the battery is full charged have you bridged the terminals on the solenoid to determine whether its faulty
Iansmi1972
« Reply #3 on: June 13, 2021, 07:43:52 AM »
When I turn the key the lights on the dashboard go off
Bar Vitelli
« Reply #4 on: June 13, 2021, 11:19:30 AM »
Something similar happened to one of my cars, I can’t explain why the fix worked but effectively the chap sprayed a load of WD40 into the lock and turned the key on and off about 50 times. Keep an eye on your battery charge as it may run it down.
Every cloud has one...
« Reply #5 on: June 13, 2021, 04:15:47 PM »
If the dash lights go out when you turn the key to start, I would check the battery sounds like it might be goosed
Iansmi1972
« Reply #6 on: June 13, 2021, 06:55:41 PM »
Thank you all guys defo think it is the battery as it is totally dead after 8hrs on charge
New battery tomorrow and again thank you
« Reply #7 on: June 14, 2021, 12:20:28 AM »
