Author Topic: BIS Front shocks  (Read 3000 times)
andyzeetec
  • 126 BIS
BIS Front shocks
« on: September 01, 2020, 03:42:18 PM »
Can anyone tell me if this is the correct front shock absorber for the BIS?
I've looked up the Fiat part number which  is 4048307
On ebay the 'check if it fits vehicle' states it fits, but on checking with supplier they say its the incorrect part. Baffled!
https://www.ebay.co.uk/itm/173270878855
andyzeetec
  • 126 BIS
Re: BIS Front shocks
« Reply #1 on: October 05, 2020, 09:38:39 PM »
Update..
For future reference incase anyone searches for BIS Shocks, these are the cheapest I managed to find front shocks for the BIS.. KYB Kayaba Front Shock Absorber part 443005, £30 the pair.
..although the supplied rubber bushings are incorrect. No problem as these can be purchased elsewhere. I bought the bush kit from a very helpful seller on ebay, Stefania from Ricambifiat500spares. All in all still worked out cheaper than other suppliers. Note: Top bushes are different to the bottom bushes.
https://www.ebay.co.uk/itm/264653814189
So the reason I wanted to renew the shocks, one had a very slight leak and MOT was due. Once off the car, BOTH old shocks were surprisingly a lot easier to compress compared to the new ones. Fitting was straight forward once I worked out the positions of the rubbers, metal cups, washers etc, shish kebab comes to mind.
The KYB shocks have a larger diameter shaft/thread aswell. Various supplied kyb flat washers cannot be used due to the overall diameter being too large. Solution is to drill out the new bush kit or old shock washer/s to suit. So its a bit of mix and matching between the 2 bushing kits.
The front end of the car has definately firmed up, handling has also improved. pics attached front shocks and rubbers bush kit...
Next is to source Rear shocks as the back end is a bit too bouncy, although  surprisingly the car still passes an mot. So after a bit of research the KYB part # 443006 comes up as a fit for the 126BIS which is actually incorrect. KYB's site states the mounting type as Top pin, Bottom pin which is okay for the aircooled 126 but not the 126BIS. The BIS is Top Pin, Bottom eye.
It’s only the rear shocks that are specifically different for the BIS model.
Suppliers are limited, so Ricambio looks favourite at the moment, unless of course if anyone else knows a supplier, manufacturer and part number.
https://www.ricambio.co.uk/rear-shock-absorber-fiat-126
« Last Edit: October 06, 2020, 06:35:40 PM by andyzeetec »
Abarth982
« Reply #2 on: October 06, 2020, 08:07:32 AM »
Thanks for info.  Mine are on the 'to do' list but a few pages away  :D
Njkip
« Reply #3 on: March 30, 2021, 11:06:28 PM »
Thanks too.....👍👍
126redbomb
« Reply #4 on: April 17, 2021, 11:36:15 PM »
Great post Thank You :thumbup
Amateb8
« Reply #5 on: April 24, 2021, 11:04:39 AM »
I replaced my rear shocks on my Bis two years ago. It made such a huge difference in the ride. Before I replaced the rear shocks, it was bouncy (but acceptable) and made a slight rattling noise. Now it drives beautifully again.
My front shocks are the original ones. How did you know it needed replacing, as it has a lift spring front suspension.
andyzeetec
  • 126 BIS
« Reply #6 on: April 24, 2021, 11:55:44 AM »
I plan on replacing the bouncy rears once it warms up a bit. 8) Did you change the coil spring rubber cups aswell?
Reason I changed the fronts was the oil seals started leaking, such a difference to ride too. :good:
andyzeetec
  • 126 BIS
« Reply #7 on: September 23, 2021, 09:08:45 PM »
Finally bought the rear shocks, will update on any improvement once fitted.
andyzeetec
  • 126 BIS
« Reply #8 on: April 08, 2022, 08:40:16 PM »
Finally got round to fitting rear shocks. After removing rear seat started undoing top mount and whole lot was loose due to rubber mounts perished so explains the rattly noise from back of the car. Included some pics, spring bottom rubber seal was shot so replaced those, also bead blasted (silver in pic) and painted spring and top mount metal cup with a resin paint. Work in progress, haven't had time to do the other side just yet.
andyzeetec
  • 126 BIS
« Reply #9 on: June 07, 2022, 12:44:11 PM »
..well finally got round to replacing rear shocks and wow what a massive difference in the ride and handling, feels so much safer. Before I replaced them it was bouncy and leaned round bends, although acceptable as it passed MOT, but now its firmer with very slight bounce and literally drives like its on rails.  ;D :yahoo:
« Last Edit: June 08, 2022, 12:33:22 PM by andyzeetec »
