Author Topic: What did you do to your 126 today ???  (Read 54234 times)
Bar Vitelli
« Reply #390 on: December 14, 2018, 11:53:07 AM »
Took the Silver to be fixed, the gears are not working properly, it only does 2nd, 3rd and 4th, no 1st and no reverse, I was hoping to get it back today but it looks like its going to be an overnight job. I miss it already.  :(
Every cloud has one...
« Reply #391 on: December 14, 2018, 05:34:26 PM »
Nothing, but the pile of new parts is getting bigger and bigger. The engine that's going in has arrived, hopefully rebuild during the colder months.  The tinware, suspension parts are ready to be blasted and powder coated. I found a place to do the banded 12" Steels. I cant wait until the spring to start with the angle grinder.
with any luck I will meet my deadline of 2 years.  ;D
Bar Vitelli
« Reply #392 on: December 17, 2018, 05:15:09 PM »
Sorted the Silver, the plastic gear selector bush had disintegrated, thankfully I had a rubber spare! There’s nothing more satisfying than having a spare part in stock that you actually use! We did not do the job right the first time though, the 13 mm fixing bolt came loose and the gear stick lifted out of the socket as I was driving! All good now and my little car is home safely!  ;)
mintex
« Reply #393 on: March 23, 2019, 09:10:34 PM »
fitted a new (second hand) stater, now i can take it for its mot next  :D
Dave
Maluch_UK
« Reply #394 on: March 24, 2019, 09:32:49 PM »
Trying my very best to sort out the many rust holes  :-
DeVilleChris
    • Club 126 UK
« Reply #395 on: March 25, 2019, 12:28:36 PM »
I thought that small hole at the bottom of the spare wheel well was for drainage? :o
1979 Fiat 126 DeVille
1979 Fiat 900T Amigo
Maluch_UK
« Reply #396 on: March 25, 2019, 12:46:54 PM »
I was debating with myself when I was fixing the rust holes under the battery shelf whether I’d need the little drainage holes or not. My thought at the time was I’ll never take the little car out when it’s wet. I’ll maybe reinstate them
« Reply #397 on: March 25, 2019, 05:52:52 PM »
If it fills up with water it'll help keep the front end down on the straights  :P
Maluch_UK
« Reply #398 on: March 25, 2019, 06:06:22 PM »
Hah noted
Bar Vitelli
« Reply #399 on: March 28, 2019, 01:14:00 PM »
Tried to fix one thing and broke another... :(
Bar Vitelli
« Reply #400 on: April 01, 2019, 10:17:00 PM »
8 hours working on the Black engine, we may have fixed it, will find out for sure tomorrow!   8)
Maluch_UK
« Reply #401 on: April 14, 2019, 06:57:52 PM »
Replacement windshield purchased (thanks for the heads up Vitelli) and now in the process of sanding down the body.
Bar Vitelli
« Reply #402 on: April 14, 2019, 07:29:21 PM »
Great work, Allan, there are 3 things that you need as a minimum when working on a 126, a jack, a set of axle stands and a mug of coffee so it’s great to see that you have all of those in your picture!  ;)
« Reply #403 on: April 15, 2019, 06:29:07 PM »
I gave luigis battery a retro look :thumbup
Yoshimisumi
« Reply #404 on: April 28, 2019, 09:40:45 PM »
I had a great morning at the Bicester Heritage Sunday Scramble today, quieter than normal but it was presale only so assume they're having to restrict numbers.
I know I threatened last time but we should organise a mini gathering there at the next one? I'll try and be on the ball when the tickets are being released.
A few extra photos thrown is as well.
Sent from my moto g(6) using Tapatalk
« Last Edit: April 29, 2019, 10:13:23 AM by Yoshimisumi »
