Author Topic: Fuel injection Cinquecento on 126 engine...  (Read 2960 times)
Topolino
« on: March 11, 2013, 05:06:02 PM »
Excuse but after using the seach field I did not find where I was looking for. A few weeks ago I spotted a 500/126 engine which had a total set up of a Cinquecento 900. It came with gasintake/single point and computer. I remember that that they also used a larger belt with tensioner. This tensioner was mounted at the place where the gaspump should be.
Was it on this site? Do you know more?...please give me a link/linki. Thank you.
This topic was formally known as 'Looking for link 126 single point engine. Was it on club126uk?...'
« Last Edit: March 11, 2013, 10:38:03 PM by Topolino »
DEYAN IYI
Topolino
Re: Looking for link 126 single point engine. Was it on club126uk?...
« Reply #2 on: March 11, 2013, 05:37:56 PM »
Hi there. Thanks. I'll guess the one above is the one.
Wouldn't be this the cheapest way to tune up you two cilinder engine? I'll wonder if you nee to make all the parts your self or that the Italians have some in stock???
ape20ff
Re: Fuel injection Cinquecento on 126 engine...
« Reply #3 on: March 20, 2013, 10:48:30 PM »
Hello.
I don't know if it's the cheapest way to tune up your engine.
I can tell you  where some parts are from.
You need to make some parts by yourself, they aren't all in stock.
The pulley on the crankshaft is from early injected fire engine, for exemple old fiat punto 55.
The pulley on the alternators is from alfa 33 water pump.
the resti is home made,customized.
If you can do it by yourself maybe you can get a poly v kit for little money.
Mind! There is no centrifugal anymore so if you want to use that parts you must add an external oil filter.
You can find poly v kit for 500-126 with or without trigger wheel.
People use centrifugal and poly v taking pulley from injected cars.
I don't know where to find parts, I think from fiat too.
Maybe from 899 i.e. or later fire enginw like 1.2...
I don't know but I saw.
Look at this video:
http://www.youtube.com/watch?v=9QxbrwFis_w
Bye.
