Author Topic: :cry: Bad Christmas  (Read 5634 times)
Fiat500f
Re: :cry: Bad Christmas
« Reply #75 on: March 10, 2013, 04:07:53 PM »
I've got a steering column and stalks you can have, it's from a Lhd  but I'm sure it's the same
« Reply #76 on: March 29, 2013, 06:01:55 PM »
The sun came out so I had another look at the steering column, The steering lock had been damaged, so was stopping the actual shaft from turning.
It looks like they used a lot of force to cause so much damage.
Out with the trusty angle grinder and the damaged part is removed. Works OK but I will no longer have a steering lock.
Next job to straighten the bracket and weld back in place.
« Reply #77 on: April 25, 2013, 07:23:02 PM »
I have had time 'and weather' to get on with Beryl again.
Finished removing all the 'tar' sound insulation. 12KG!!!! removed. Interior the sprayed with underseal.
The bracket straightened, drilled and painted. Dashboard was worse than I thought but straightened and repaired.
Kent126
    • Facebook Profile
« Reply #78 on: April 25, 2013, 07:56:56 PM »
How are you going to repair the bent roof?
1974 Italian Fiat 126 TA
2008 Fiat Panda 100HP
grubscrew
« Reply #79 on: April 25, 2013, 08:14:23 PM »
 Tar stuff, mmmmm , they (FIAT), even used it in the 500`s, . It is there for reducing the "drumming"  effect , as it has sound insulating properties, you may find its louder in the cabin after its removal, and yes it can hold a film of water but does`nt absorb the damp as fabric insulant tends to. I shall be using some of these tar mats as they are quite good. Mike.
All things Italian.
« Reply #80 on: April 25, 2013, 08:24:13 PM »
Once the car is mobile, I have been offered the use of a Portapower. I plan on using the long poles/rods and simply pushing both sides out at the same time.  :- ??? ::)
Re the tar, I had a lot of water trapped under it, it has bubbled in a few places. I will try it and see how it goes with just the mats, if not I will need to buy Dynomat.
« Reply #81 on: May 03, 2013, 07:00:43 PM »
My film of water was UNDER the tar  ??? ::) :cry:
« Reply #82 on: May 03, 2013, 07:17:55 PM »
[/quote]
I doubt it's normally used on submersibles.
I am fairly certain you will need something to replace it, have a good look around though, there are so many different products out there.
http://www.frost.co.uk/eastwood-thermo-coustic-sound-deadener-material-9-pieces.html
http://www.ebay.co.uk/itm/18-SHEETS-23sq-ft-Car-Vehicle-Sound-Deadening-Insulation-Proofing-Pads-Absorber-/281088893100?_trksid=p3284.m263&_trkparms=algo%3DSIC%26its%3DI%26itu%3DUCI%252BIA%252BUA%252BFICS%252BUFI%26otn%3D21%26pmod%3D170906420858%26ps%3D54
« Last Edit: May 03, 2013, 07:23:45 PM by Hazey-n-Marc »
Lloyd74
« Reply #83 on: May 03, 2013, 10:40:36 PM »
is this the car from practical classics in which case my heart snapped, good luck and so good to see you haven't abandoned it a great testament to you steely resolve!
« Reply #84 on: May 03, 2013, 11:04:47 PM »
Yes that's the one.
