Author Topic: Project 126 Aygo  (Read 34786 times)
pietschokkenbroek
Re: Project 126 Aygo
« Reply #15 on: October 21, 2012, 07:51:27 PM »
Hey Da Londo, Thank you! If you're in the neighbourhood let me know! How is your car coming along?
Seabee1978126
« Reply #16 on: October 22, 2012, 01:38:07 PM »
WOW!! This job is amazing! Thank you for keeping us updated on your progress!!!! Im very impressed in all of the love that your putting into the car. I only wish I had the time to do what your doing. One of these days... Keep up the amazing project, im real excited to see her up and running!
pietschokkenbroek
« Reply #17 on: October 24, 2012, 07:28:08 PM »
Thank you very much, Seabee!! I trying to do my best, and it does take a lot of time, but I am enjoying every ;D most minutes of it!!
I am following the starting problems of your car. It's great to drive one of these cars, especially in Italy!!
« Last Edit: October 24, 2012, 07:34:28 PM by pietschokkenbroek »
ronb1967
« Reply #18 on: October 24, 2012, 10:16:26 PM »
nice job,  any idea on the gearing,as the Aygo used 14 inch wheels so i imagine that you will have excellent accelaration but not much top end  i think im right in saying that the biggest tyre to fit under a standard rear arch is a 155/70r13. what about gearbox oil level ? you may need to over fill to make sure the gears dont run dry
im currently looking into the vauxhall/opel corsa 973cc 3 cylinder engine fitted in the older corsa's because they ran on 13 " wheels so gearing should be reasonable and whole cars can be purchased for about £300/400. im just waiting for a reasonable mot failure corsa in my general area
good luck with the build and keep the photo's coming  :thumbup
pietschokkenbroek
« Reply #19 on: October 27, 2012, 07:18:56 PM »
Thanks Ronb. Please correct me if I am wrong but I thought because the Toyota runs on lower tyres the difference is relatively small (see tabel).
Indeed the oil level in the gearbox is something I am not very convinced about... But because there are all rotating gears, oil willl be tossed around anyway. I will probably stay very focussed on grinding noise that might appear.
I didn't know Corsas were fitted with 3 cilinder engines these days. Sounds like a sensible option. I'll be keeping an eye on your posts!!
« Reply #20 on: October 28, 2012, 09:15:47 AM »
Could you send us the link for the tyre diameter calculator please Piet, people are always asking about that, will be handy to have on the forum.
Marc
« Reply #21 on: October 28, 2012, 09:57:22 AM »
Marc
http://club126uk.co.uk/smf/index.php?topic=2332.0
« Reply #22 on: October 28, 2012, 10:12:50 AM »
Cheers Pete, hadn't seen that before :$
pietschokkenbroek
« Reply #23 on: October 28, 2012, 11:18:05 AM »
use it wisely! ;)
pietschokkenbroek
« Reply #24 on: October 28, 2012, 02:42:27 PM »
This week I recieved some parts to continue with the drive shafts. I also ordered a chrome rear bumper  ;D It might be a bit early for this but I would like to see if I can make a nice exhaust outlet under the bumper.
« Last Edit: October 28, 2012, 05:02:38 PM by pietschokkenbroek »
Madd
  • Poland
    • Street-Roulette
« Reply #25 on: October 28, 2012, 04:09:49 PM »
Brand new bumper? Where did you find this?
Fiat 126 RHD & BOSMAL :) in Poland
Instagram: @madd.moss
pietschokkenbroek
« Reply #26 on: October 28, 2012, 05:02:04 PM »
I found it at a dutch supplier: fiat vd Laan.
http://www.fiat126vdlaan.nl/catalog/index.php?cPath=28
If you need help with translations, let me know.
« Last Edit: October 28, 2012, 05:04:25 PM by pietschokkenbroek »
ronb1967
« Reply #27 on: October 29, 2012, 01:56:03 PM »
Are those the modiffied C.V joints to replace the rubber type ?
pietschokkenbroek
« Reply #28 on: October 30, 2012, 02:00:14 PM »
Yes correct! I think they are probably the weakest link in the driveline. Besides, I need them to compensate for the extra angle in de shafts.
pietschokkenbroek
« Reply #29 on: November 11, 2012, 08:04:25 PM »
I have been fiddling with the gear linkage ::) I want to use the aygo gearstick mechanism (which is a brilliant but simple working piece of engineering  :thumbup) which in real live the aygo is turned front to back. On the gearbox itselfs are two levers that need to be operated. The photos show the mock-up of the sollution I came up with... If I did my homework correctly :headscratch: the gearshift pattern is as it should be.  :thumbup
Toyota Aygo shift mechanism (I still have to find a way to make the push-pull-cables longer) The photo also shows the hole I had to make to fit the alternator :(
I said it was just a mock-up  :$
« Last Edit: April 16, 2014, 09:24:36 AM by pietschokkenbroek »
