Author Topic: Wheel lock nuts  (Read 1911 times)
RicePuddin
  • Guest
Wheel lock nuts
« on: August 17, 2011, 06:57:17 PM »
Does anyone know where I can get a set of wheel lock nuts for a 126 bis?
As I have a disc break conversion the standard Fiat type work there but I have none for the rear.
Eklipze3k
Re: Wheel lock nuts
« Reply #1 on: August 17, 2011, 07:13:54 PM »
If they work on the front, they'll work on the rear. Unless you changed the front stub axles (and therefore hubs) for Cinq/Sei ones too(which use an M12x1.25 pitch)? In which case, any M12x1.5 locking nuts will do fine for the rear.
