Author Topic: heat shields on a tunned engine?  (Read 12818 times)
Re: heat shields on a tunned engine?
« Reply #15 on: February 15, 2011, 06:06:13 PM »
That rubber hose should be OK for a start up but I would keep an eye on it when the engine is hot as it may soften & colapse inwards on high revs. I am running with the 126 594 ccs metal tube & rubber connectors. I have been looking in all my books today about that backfire thing. Not enough time now to tell the whole story but you will be OK putting it where it best suits you  [-/
alapimba
« Reply #16 on: February 15, 2011, 08:11:32 PM »
Can you help me with the earth strap? Where under the dínamo i have to connect? http://img20.imageshack.us/i/imagesjl.jpg/
« Reply #17 on: February 15, 2011, 09:18:43 PM »
That nearest M8 bolt at the base of the ally dynamo mounting casting is easiest.  [-/
alapimba
« Reply #18 on: February 15, 2011, 10:18:17 PM »
ah ok
i thought it had to be really bolted to the dinamo directly
now it's clear :)
alapimba
« Reply #19 on: February 17, 2011, 10:20:35 PM »
the car is running :D
runs well but as everything is new it still smokes a lot.
Anyone can tell me how to tune the carb? it's a weber 28 as i said before.
DEYAN IYI
« Reply #20 on: February 17, 2011, 11:27:45 PM »
 :D Congratulations!!!  **-
You need a fuel air meter (in a car service for example). If you can't reach the correct mixture, you'll have to play with the jets. No other way to do it "by book" with the new camshaft and exhaust :D
« Last Edit: February 17, 2011, 11:31:33 PM by DEYAN IYI »
alapimba
« Reply #21 on: February 19, 2011, 11:03:57 PM »
hello
while putting the engine in one piece again i found some parts that i didn't used because i forgot where they were  :oops:
One of them is this ones: http://cgi.ebay.de/FIAT-500-126-ACCELERATOR-THROTTLE-CABLE-LINKAGE-CLIP-/200461215750?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2eac6b6806
Anyone can show me where to use it? Thanks
« Reply #22 on: February 19, 2011, 11:16:15 PM »
You'll definitely need those if you don't want the throttle linkage to fall apart :)
There's a rod that has both ends bent which goes from the throttle cable linkage (near the air filter housing) to the end of the throttle plate rod lever on the side of the carb that faces you.
alapimba
« Reply #23 on: February 19, 2011, 11:19:15 PM »
weird i had it togehter with the bolt from the clutch cable.
anyway.. do you have a picture or scheme of the car with this so i can understand better please?
« Reply #24 on: February 19, 2011, 11:22:27 PM »
(Used your picture Rusty  :P)
Circled in red is where the clips go
« Last Edit: February 19, 2011, 11:29:25 PM by GTMaster »
alapimba
« Reply #25 on: February 19, 2011, 11:25:50 PM »
hum that one i have.
maybe it's another part. i have to take a picture so you can help. theres any thing similar to this near the cluth cable?
« Reply #26 on: February 19, 2011, 11:32:29 PM »
The cables that run under the car are the handbrake cables, speedo cable (at back of gearbox near the tunnel), clutch cable, starter cable (if it's the old type of starter motor) while the throttle cable and choke cable are led up into the engine bay....
alapimba
« Reply #27 on: February 19, 2011, 11:38:57 PM »
it's this.
just found
« Reply #28 on: February 19, 2011, 11:41:53 PM »
That holds the clutch cable in place on the side of the gearbox (left hand side above rubber gearbox mount), with a spring washer and M6 nut if i remember correctly (could be an M6 bolt)... the bottom of that bracket goes into a slit on the gearbox...
« Last Edit: February 19, 2011, 11:43:43 PM by GTMaster »
« Reply #29 on: February 20, 2011, 08:21:54 AM »
Some clutch cables have the gearbox mounting bracket fixed to them & others use a separate bracket  [-/
