Author Topic: Disk Brakes  (Read 3029 times)
f500126
Disk Brakes
« on: March 24, 2003, 05:42:18 PM »
Any easy method of getting a front brake disk up set up for a 500? :?:
Carrisma
  • Guest
Disk Brakes
« Reply #1 on: March 26, 2003, 07:29:39 PM »
You can by a complete set of diskbreaks for a Fiat 500 for 220 E at this link.   Click on Breaks
 http://www.fiat500sport.com/def.asp?l=ENG&sku=146317201FE
There is a photo of what you get...
f500126
Disk Brakes
« Reply #2 on: March 26, 2003, 10:01:41 PM »
Nice piece of kit although a bit expensive!
I did hear that someone had done the mod with 850 components not sure what model though or any problems with the conversion??
Carrisma
  • Guest
Disk Brakes
« Reply #3 on: April 01, 2003, 06:46:45 AM »
Hmmmmmmmm, I don't find this expensive at all.
If you by a complete set of calibre and discs and brake shoes for any other car's you'll find out that in some cases it is even more expensive.
Then you got to have in mind that this is not standard Fiat 500 parts but special handmade racing parts.
Many Tuning and racing parts for Fiat 500, 600 and 850 are at the price level as formel 1 parts because they not are in production any longer and are an especially handmade part.
Anyway... The 850 disks are mostly used on a Fiat 600, because they fit directly on the 2 bolts. I never seen 850 brake parts on a Fiat 500.
Normally on the Fiat 500 one has to use the spindle from a Fiat 126 with 3 bolts instead of only 2 on original Fiat 500 for mounting the adapter plate for the brake calibre.
The disk and the calibre are normally taken from Fiat Uno. but one has to resize the disk seize for fitting inside the 12" wheels.
It's quite complicated to make this kit from scrap parts, and I do think that the time one has to spend on doing so is more worth than 220 ?
shagmeister
Disk Brakes
« Reply #4 on: August 24, 2003, 02:33:07 PM »
i have a 126 and an uno that i am going to scrap, if i was to purchase the mounting plates and resized discs from 500sport would my front discs bolt straight on??  Thanks neal
126-Poland
    • http://www.fiat-furious.pl
Disk Brakes
« Reply #5 on: April 21, 2005, 11:54:12 AM »
Disk Brakes
« Reply #6 on: April 21, 2005, 04:49:12 PM »
Excellent looking site with some nice conversions. It's a pity that there is no english version of the site :cry:
Quote from: "126-Poland"
You can also install discs from fiat 125p.
instructions how to do it are on our web page www.fiat-furious.pl
http://fiat-furious.pl/html/tuning_a/ham_tarczowe_126/ham_tarczowe_126.htm
and
http://www.fiat-furious.pl/html/tuning_a/ham_tarczowe_v2_126/ham_tarczowe_v2_126.htm
good luck! :)
