Author Topic: 40mm pirelli spacers.40 DCOE to ALQUATI  (Read 10658 times)
« Reply #15 on: October 17, 2006, 10:09:04 PM »
oh right that surprised me, keep going! will find somthing spot on eventualy hopefully with this mount.
+ CLUB (ENQUIRIES): fiat126club@gmail.com
« Reply #16 on: October 18, 2006, 06:57:21 PM »
mmnn...well,bis mount kind-off works,but the alloy plate i fitted as a top panel is resonating,so,im laminating this to a 9mm malaysian ply panel............dont larf,remember mosquito airplanes??? timber/alloy and ply with two merlins nailed on...........good enough for 633 squadron=good enough for me!! :cool:
« Reply #17 on: October 18, 2006, 07:19:42 PM »
haha, its getting a bit wartime this, dave did you know apparently the 126 aircooled engine is based on an airplane engine, just cut in half?
« Reply #18 on: October 19, 2006, 07:45:28 PM »
fookin hell chris.....glad im not gna fly in that..............
« Reply #19 on: October 20, 2006, 04:26:43 PM »
is nearly half a vdub engine and they have been known to appear in planes....
« Reply #20 on: October 20, 2006, 05:15:36 PM »
haha dave the ww2 survival rate in a 126 powered plane wouldnt be very good  :lol: imagine a bis engine! would be hard to change the headgasket during the first sortie  :lol:  :lol:
Stuey do you know anyone who has ever put a vw engine in a 126? Ive heard its been done but never seen it.
regards
« Reply #21 on: October 20, 2006, 06:36:11 PM »
im sure ive seen one some where in my enourmous (car :) ) magazine collection ill have a dig....
ive got a great 126 brochure i need to scan in too...
« Reply #22 on: October 20, 2006, 09:05:24 PM »
Trabant engines are used for those little fold up planes. So I don't see why a 126 wouldn't.
« Reply #23 on: October 21, 2006, 09:49:15 AM »
ok guys,road tested last night........still holding together,carb is know firmly attacthed to the motor!! less vibrating=improved fueling etc.
still a tad rich tho.see my other post about plugs
so the laminated idea is working so far,coupled with the complete spring/rubber bushes from an aircooled (the bis one was too high) the carb is mounted to this via a custom bracket and the central bolt gives full adjustment for the angle of the carb,so not putting any strain on the softmounts..........lets see how this goes............... :roll:
« Reply #24 on: October 22, 2006, 08:32:17 PM »
This is the final version i hope of the troublesome carb mount,its running well and holding together,but.....i have not painted or otherwise finished it, as im kind off expecting trouble again..........
Daves carb mount
Posted byC.Lakin
« Reply #25 on: November 04, 2006, 10:29:02 PM »
well.update,carb mount doing ok,rich running was down to a damaged needle valve damper spring..= flooding carb....complete item renewed from 'fastcars',,,great guy,new weber part just 3.00£.i went down a size too,1.50mm from 1.75mm........
« Reply #26 on: November 05, 2006, 12:47:22 AM »
glad to here its backup and running dave, you seem to be in F1 terratory at the moment
« Reply #27 on: November 05, 2006, 08:30:56 AM »
thanks pete..if anyone does go down the route i've taken i can sure save them some time!!!!!......
how did the spring cut go?
« Reply #28 on: February 03, 2007, 01:51:59 PM »
update on the rubber spacers for the weber 40 carb,nanni stock them,as does turbo 1 sport,but nanni now also stock alloy ones with o ring inserts,i've just ordered some to see how they go.......the rubber ones seem ok at the mo,but i've never been keen on them.
Tomasz
« Reply #29 on: February 05, 2007, 04:04:04 PM »
What do you guys think to this.  How much extra power would this give me/would it fit without problems?
http://cgi.ebay.com/ebaymotors/FIAT-500-DELLORTO-40-DHLA-CONVERSION-KIT_W0QQcmdZViewItemQQcategoryZ33550QQihZ016QQitemZ260079804174QQrdZ1QQsspagenameZWD1V
