Author Topic: Oil sump removal...  (Read 168 times)
Me_and_BIScuit
Oil sump removal...
« on: September 18, 2020, 04:52:45 AM »
Hello, and I need some help with removing the oil sump. Reason being that I snapped a bolt on that oil impeller cover, which I'm unable to remove and might have to drill it out now (I sure am a magnet for worst case situations lol) Anyways, I got all the bolts off the sump but it just won't budge. Tried to break the seal with a thin knife in various places - nothing. Do I have to take the impeller off to release the sump? Any suggestions and tips that could help here? By the way I'm trying to do this engine in. I just can't be bothered taking it out again
Guldbergdk
Re: Oil sump removal...
« Reply #1 on: September 18, 2020, 08:31:39 AM »
Its a BIS right? You have to take the water pump impeller off yes. Its what keeping the drive shaft for the water pump / oil pump in place.
The sealing for the impeller is some carbon stuff, so it breaks real easy and its pretty expensive. You might be best of ordering a kit. The impeller might require some force to be removed from the shaft.
https://www.fdricambi.com/en/fiat-126/heating-cooling/vs1026-original-water-pump-seal-fiat-126-bis
https://webshop.fiat500126.com/en/engine-parts-und-gaskets/other-engine-parts/water-pump-repair-kit-brand-metelli
https://www.fdricambi.com/en/fiat-126/heating-cooling/vs1025-water-pump-seal-fiat-126-bis
Me_and_BIScuit
« Reply #2 on: September 20, 2020, 08:39:52 PM »
Thanks for your help! Yes, it's a Bis. Now do I need a special kind of socket to get that nut off the 'peller? The nut has little metal things on both sides and none of my sockets fit on it. On second look, it looks like it could be a special kind of washer with lugs that are pressed against the nut sides? Do I need to bend these down somehow?
« Last Edit: September 20, 2020, 08:42:34 PM by Me_and_BIScuit »
Njkip
« Reply #3 on: September 20, 2020, 11:13:27 PM »
By the sound of it it must be a locking washer, the tabs are there to prevent the nut from loosening....just bend them flat which will allow the nut to be undone....?
Guldbergdk
« Reply #4 on: September 21, 2020, 09:01:15 AM »
It shouldnt be a nut but an socket head bolt like in the kit here https://webshop.fiat500126.com/en/engine-parts-und-gaskets/other-engine-parts/water-pump-repair-kit-brand-metelli
Could you post a photo?
