Author Topic: Wheel nut torque  (Read 155 times)
Guldbergdk
Wheel nut torque
« on: September 02, 2020, 11:07:18 AM »
I tighten the wheelnut by hand (assuming thats around 7NM) and back it off 30degrees as per instruction. But this means that its more or less free to rotate. I staked it, but its hard to “fill” the gap in the axle where the staked part is hammered into. Thus the nut can rotate a couple of degrees back and forth. It just seems wrong that it should be so loose?
Guldbergdk
Re: Wheel nut torque
« Reply #1 on: September 17, 2020, 12:45:56 PM »
Anyone tried to change the front bearing and had to refit the wheel nut?
sistemgeriyukleme
« Reply #2 on: September 29, 2020, 12:34:39 PM »
hope this helps
