Author Topic: How to get oil filler plug off 126p gearbox  (Read 202 times)
Iffy650
« on: July 27, 2020, 05:53:06 AM »
Does any have experience of removing the plug on the gearbox of an air cooled 126p? What size / type of socket is needed as the head on the plug is square and 13mm across the flats. Tried using a normal hex socket but the plug is stuck tight and i didnt want to strip the corners off that square head.
Any advice welcome, cheers
Macmonkey
Re: How to get oil filler plug off 126p gearbox
« Reply #1 on: July 27, 2020, 07:46:31 AM »
When I had to remove my filler plug off I used the square end of a half inch socket, it's a good fit so hopefully won't strip the head. I don't think my plug had been removed in a long time and I found a couple of gentle taps and actually slightly tightening it before loosening helped remove it. Hope this is of some help.
Iffy650
« Reply #3 on: July 27, 2020, 02:49:23 PM »
Thanks Chris and Macmonkey,
I'll give the square end of the extension bar a go.
« Reply #4 on: July 27, 2020, 11:57:29 PM »
These old 1/2" wrenches are excellent for this type of job.
