Author Topic: Fast idle solenoid adjustment on BIS  (Read 363 times)
andyzeetec
  • 126 BIS
« on: July 03, 2020, 07:06:41 PM »
Anyone know how to adjust it.
Its either the screw at top or nut underneath?
Thanks.
Re: Fast idle solenoid adjustment on BIS
« Reply #1 on: July 04, 2020, 01:26:21 AM »
That's it in the centre of the diaphragm, you can only adjust it when the fan cuts in
andyzeetec
  • 126 BIS
« Reply #2 on: July 04, 2020, 09:17:50 AM »
So the screw in the middle on top.
Thanks Pete.
« Reply #3 on: July 04, 2020, 04:45:57 PM »
Yes that's the one, the speed should be set about the same as the idle when the fan cuts in
andyzeetec
  • 126 BIS
« Reply #4 on: July 28, 2020, 07:42:28 PM »
All adjusted , engine doesn't nearly stall now when the fan kicks in. Just in time for Friday looking at the weather forecast. Thanks Pete
