Author Topic: 126 bis cylinder head gasket  (Read 275 times)
mrsumner
« on: June 26, 2020, 10:34:47 AM »
Morning.Do any members know of any garage/ mechanic in NW England/East Lancashire prepared to fit a cylinder head gasket on my bis? My local repair services are not keen on undertaking this task! Cheers.
Re: 126 bis cylinder head gasket
« Reply #1 on: June 27, 2020, 01:05:57 AM »
It's quite a simple job on the Bis and can be done without removing the engine, things that need to be done and removed, Drain System oil and water, Exhaust, Rocker Cover, Carb, Inlet Manifold (their are 2 head nuts behind the inlet manifold) and Ignition Leads, the head needs to be test to see if it's warped or cracked
mrsumner
« Reply #2 on: June 27, 2020, 10:04:06 AM »
Cheers,very useful info to provide for a garage to have if considering to undertake the repair.
