Author Topic: Turn signal issues  (Read 397 times)
LoGiTo
Turn signal issues
« on: March 16, 2020, 04:45:09 PM »
Hi.
I had really slow blinking turn signals on my 126p, it was flashing every 2 or 3 seconds (both sides).
I went ahead and changed the turn signal relay. It was a mechanical one just like the silver one in the attached picture (DLB-SL-12V 2X21W - 4W+2W).
Changed it to a new electronic relay(the black one in the picture is what I changed it to), and now the turn signals don't even work at all. :( The feedback light glows constantly on the dashboard when the signals should be flashing.
The hazard lights were working fine all along, but that has a different relay. Bulbs are not burnt out, all of them works.
What could be the issue here?
Maybe I'm just missing something or doing something wrong.
Thanks in advance.
Re: Turn signal issues
« Reply #1 on: March 16, 2020, 08:01:31 PM »
Have you tried adjusting the original mechanical unit by carefully taking the metal case off and bending the fixed contact nearer the bi-metalic strip
LoGiTo
« Reply #2 on: March 17, 2020, 07:21:08 AM »
In all honesty, I didn't even think of fixing the old one.
I am going to try what you said tho, for sure.
Neville Minuti
« Reply #3 on: May 17, 2020, 09:38:36 PM »
Hi, saw your post today. I had a similar issue on my 1987 air cooled model. I changed the relays but to no avail. Ultimately I had a the front rhd indicator unit terminals switched.
rmbruton
  • before
« Reply #4 on: May 22, 2020, 10:15:54 PM »
you can buy the original relay from fiat500vdlaan.nl item lp7565. £15
