Author Topic: Stalling under Load  (Read 700 times)
Azrael81
Stalling under Load
« on: August 18, 2019, 08:51:37 AM »
I've recently bought my 1990 BIS as a project car to work on,
While it runs, the engine stalls as soon as i put a gear in, now
with the excessive fuel smell, i suspect the carburettor may be running
way to rich.
Am i on the right track or is there be anything else i should look out for?
Guldbergdk
Re: Stalling under Load
« Reply #1 on: August 20, 2019, 08:11:50 PM »
What happens if you rev it without putting it in gear?
Azrael81
« Reply #2 on: August 20, 2019, 08:28:55 PM »
It revs normally, and keeps running.
Minijohn
« Reply #3 on: August 23, 2019, 04:52:42 PM »
Id check the simple stuff first - if there’s a fuel filter - is it blocked.
Azrael81
« Reply #4 on: August 24, 2019, 04:23:52 PM »
No fuel filter unfortunately. Replaced the air filter, carb now seems completely out of whack.
Sent from my Phone 2 using Tapatalk
« Reply #5 on: August 25, 2019, 02:07:11 PM »
check the carb for air leaks, make sure all the air pipes are in good condition and in the right place
Azrael81
« Reply #6 on: August 25, 2019, 02:38:31 PM »
They do seem to be in the right place. However, I'm not sure if the distributors diaphragm is supposed to be movable.
« Reply #7 on: August 25, 2019, 02:51:02 PM »
It should be screwed to the distributor - 2 screws either side
Azrael81
« Reply #8 on: August 25, 2019, 03:03:07 PM »
It seems like one of the screws went missing, the other one  wiggled it's way out and I found it underneath the car.
Azrael81
« Reply #9 on: September 11, 2019, 05:47:58 PM »
So I removed the dizzy to get the diaphragms fixed, and in the process seem to have messed up the timing to the point where the engine is just turning over. The manual gives some indication on how to adjust the timing, but it looks like I have to take the valance off to do it. Is there a way to set it right without removing the valance?
« Reply #10 on: September 11, 2019, 07:59:20 PM »
You don't need to remove the rear valance, loosen the distributor nut and take the top cap off, align the front pulley to the 10 deg point (green) connect a 12v test lamp bulb between (red and earth) with the ignition on move anti-clockwise till the goes on and off and clamp
