Author Topic: Side lights.  (Read 854 times)
Magic
Side lights.
« on: August 13, 2019, 06:15:31 AM »
Hi Guys
I purchased some led sidelights to replace the standard ones.
They are T4W as per original but do not want to work, Is there anything I can do / change to allow them to work ?
TIA
Robbie
Da Londo
    • Fiat 126 blog
Re: Side lights.
« Reply #1 on: August 14, 2019, 09:13:25 AM »
I think you need an additional resistor for each led for them to work.
Sent from my POT-LX1T using Tapatalk
Re: Side lights.
« Reply #2 on: August 14, 2019, 12:40:05 PM »
If you are talking sidelights then they should work. If you mean indicators then you need to fit an electronic flasher unit  :)
danthemanic
  • 1987 Polski A/C
Re: Side lights.
« Reply #3 on: August 14, 2019, 04:01:49 PM »
I had a similar situation with an old motorbike.  LEDs must have polarity applied the same way, whereas normal bulbs can accept polarity either way.  Wiring a small bridge rectifier before each bulb may solve this. Or as Rusty's Uncle says, he probably has a ton more experience than I do.
Re: Side lights.
« Reply #4 on: August 14, 2019, 09:34:45 PM »
As Dan said, If you have spade connectors on the bulb holder you can just swap them round if not just cut the wires and use a terminal block to connect them.
Magic
Re: Side lights.
« Reply #5 on: August 16, 2019, 09:56:09 AM »
Yes sidelights mate I didn't think that a problem should occur but they don't want to work  >:(
