Author Topic: Fiat 126 BIS alloys  (Read 1765 times)
Fiatlove
Fiat 126 BIS alloys
« on: July 05, 2019, 06:45:14 PM »
Good Evening,
I have been searching and searching for some nice alloys to go on my BIS. I just cannot seem to find any! Any suggestions from anyone?  8)
Re: Fiat 126 BIS alloys
« Reply #1 on: July 05, 2019, 07:04:49 PM »
I got alfasud alloys on mine - 165/55/13 :thumbup most 13” alloys from Fiats from the 80s and 90s will fit such as the X1/9, Uno, cinquecento And seicento
Minijohn
« Reply #2 on: July 24, 2019, 01:37:10 PM »
I'm using Cinquecento Sporting alloys but have slot mags to fit eventually.
They're 5.5x 13 with 165/55 x 13 tyres.
The 1st picture shows one of each
« Last Edit: July 24, 2019, 01:40:46 PM by Minijohn »
« Reply #3 on: July 26, 2019, 11:51:48 AM »
Not sure what is the brand of my alloys. The tire sizes are: Front 155/65R13 73T; Rear 165/55R13 70H. The rear alloy thickness of the rear, visually, look slightly wider than the front alloys. On the face of the alloy, there is embossed WBA44350.
I think Gadge's Alfa Romeo alloys look really cool!! It looks like it was made for the car.
« Reply #4 on: July 26, 2019, 05:17:36 PM »
Slot mags look fantastic !!!!!
danthemanic
  • 1987 Polski A/C
« Reply #5 on: August 18, 2019, 03:23:13 PM »
I've got 155/65 R13s on each corner, but the front right is rubbing the front of the arch.
I've bought a cheap arch roller from eBay but I'm not having much luck with it.
I've tried looking for a smaller profile tyre, but I'm not sure that's the answer.
DEYAN IYI
« Reply #6 on: August 18, 2019, 05:19:30 PM »
155/60R13 is the same diameter as 135/80R13. The size is popular in Japan.
Probably the offset is kind of problematic as well.
danthemanic
  • 1987 Polski A/C
« Reply #7 on: August 18, 2019, 05:26:37 PM »
Did you mean r12 on that second size?
I've no idea about offset. What should I be looking at?
DEYAN IYI
« Reply #8 on: August 19, 2019, 06:38:50 AM »
My bad, sorry. 135/70R13, but it also equals 135/80R12.
Magic
« Reply #9 on: August 19, 2019, 08:03:59 AM »
We seem so limited in the UK but then you look at the cars in Poland and every car has different alloys  :o
I run 13" superlites on mine.
Robbie
« Reply #10 on: August 19, 2019, 09:05:36 AM »
My vote goes to Gadge, the best looking wheels of the bunch.
I on the other hand plan to keep it simple, respray the orig wheels and fit the medium plastic hubcaps, something like the aircooled cars had.
« Reply #11 on: August 19, 2019, 11:32:59 AM »
Those wheels will be up for sale soon as I’m planing on getting my steels powder coated :thumbup
I’m not sure why those wheels are rubbing though? The 165/5513 size has been tried so many times and on lowered or standard suspension so can’t see any reason why they won’t fit. The only thing I can think of is perhaps the arch is smaller? (Series 1 wings on a bis?)
EDIT sorry just re-read the earlier post i see your fitting 155s . I haven’t come across a 126 with 155/65s on as yet
« Last Edit: August 19, 2019, 11:37:17 AM by Gadge »
danthemanic
  • 1987 Polski A/C
« Reply #12 on: August 19, 2019, 11:36:22 AM »
They are 155/65 13, not 165/55.  I'm now shopping for a set of 165/55.
DEYAN IYI
« Reply #13 on: August 19, 2019, 05:01:59 PM »
Just realised that I am using now a friend's set of winter 145/70R13 over Panda rims. Comparing the diameter to 155/65R13, 145/70 is 2mm larger. I can't provide a pic at the moment, but there is a significant gap between the tyre and the fender.
Ricardo Regalo
« Reply #14 on: March 20, 2020, 03:49:31 PM »
mine is a aircooled from 1999, and don't know if this makes a difference, but I just installed some 145/70R13 on my rims with no problems on clearance. They are 5.5j. Actually I should have gone for the 155/65R13 which would look better (though I like the look with the ones I put on now). Both these sizes are very close to each other regarding diameter.
Don't understand why you are having problems with that tire size. I tried a 155/70R13 before on the front wheels and rubbed the inner linings on arches when turning. But I'm still considering that size for the rear wheels.
