Author Topic: Brake lights  (Read 265 times)
Brake lights
« on: May 24, 2019, 06:21:03 PM »
The issue I have is uneven brake lights. The passenger side brake light is bright and normal. However, the driver's side brake light brightness is very weak. Do I need to replace the driver's side tail light circuit board? Maybe the circuit board contacts are slightly defective. I sand papered slightly the base bulb contacts, and pushed both (prongs?) upwards for better contact with the bulb. There was no change.
Re: Brake lights
« Reply #1 on: May 24, 2019, 07:33:11 PM »
Most likely to be an earthing problem, do all the lights work properly? Check with side lights, indicators on while someone is operating the brake pedal
Re: Brake lights
« Reply #2 on: May 24, 2019, 10:18:39 PM »
Hi Pete,
As far as I know, everything works. I'll recheck tomorrow.
From recollection, i think the driver's side tail lights/brakes electricity source comes from the passenger side tail lights/brakes
Re: Brake lights
« Reply #3 on: June 06, 2019, 10:22:13 PM »
Are both the bulbs the same?
Re: Brake lights
« Reply #4 on: June 09, 2019, 06:30:20 PM »
I am assuming yes (wattage?), but I shall double check.
« Last Edit: June 09, 2019, 08:11:21 PM by Amateb8 »
