Author Topic: Fuse box - unidentified relays  (Read 519 times)
andyzeetec
  • 126 BIS
« on: May 06, 2019, 01:39:42 PM »
Hi.
Does anyone know what the 2 relays are at each end of the fuse box, as they are not shown in the workshop manual.
Thanks.
nick7nick7
Re: Fuse box - unidentified relays
« Reply #1 on: May 06, 2019, 03:52:45 PM »
big round one is indicator relay,
The other i think is for the headlight
« Reply #2 on: May 13, 2019, 01:51:24 PM »
If you mean the two outside the box i do not Know, but mine has them too, so i wish someone would shed some light on the subject. All I Know my First bis did not have them so they might be aftermarket. I plan to remove them once i re-install my wiring loom and see what happens.
p.s. try taking it out and see what does not work….  ;D
Da Londo
  • It's not the carb size that matters, it's the jet
    • Fiat 126 blog
« Reply #3 on: May 13, 2019, 04:15:37 PM »
What he says!
Sent from my HUAWEI VNS-L31 using Tapatalk
« Last Edit: May 13, 2019, 04:17:11 PM by Da Londo »
andyzeetec
  • 126 BIS
« Reply #4 on: May 13, 2019, 09:01:53 PM »
Yes, the 2 outside the box each end. The fact that the worshop manual doesn't show them suggests there was a design/revision change at some point, but the manual wasn't updated to refect the changes. Good idea, I'll give it a go at some point.
