Author Topic: fuel pump leaking  (Read 391 times)
tomviam
fuel pump leaking
« on: December 03, 2018, 02:47:56 PM »
Hi guys.
I have tried to look in the manuals about this part of the fuel pump, but unfortunately I am not able to identify it.
The point is, there is a small leak coming from that "hole" and I dont know what it could be, does anybody had the same problem or knows how to fix it?
Tomás
« Last Edit: December 04, 2018, 01:36:09 PM by tomviam »
nick7nick7
Re: fuel pump leaking
« Reply #1 on: December 04, 2018, 08:10:54 PM »
Isn't that the bleed hole for trapped air?
Sent from my S60 using Tapatalk
tomviam
« Reply #2 on: December 05, 2018, 02:25:57 PM »
I have no idea what hole is that, as said, I wasn't able to find an explanation on Haynes
« Reply #3 on: December 05, 2018, 04:00:08 PM »
Looks like it maybe the rocker pivot pin? If it is perhaps the pivot pin hole is worn due to wear. You will need to take the pump off to see what is happening
« Last Edit: December 05, 2018, 04:24:26 PM by ChrisRLewis »
Thanks to all of the Subscribers Group who contribute to keep this forum running!
Club126uk Subscription Information
tomviam
« Reply #4 on: December 12, 2018, 07:40:55 PM »
maybe but how to fix it? do I have to remove it and change it, if so, how?
« Reply #5 on: December 13, 2018, 07:40:16 AM »
Its not worth messing about with, replace it or fit an electric pump plenty on eBay :thumbup
« Reply #6 on: December 14, 2018, 05:08:12 PM »
I agree with Pete the easiest option is to fit a new pump, they are only around £15.
https://www.mister-auto.co.uk/fuel-pump/valeo-247138_g458_a021247138.html
tomviam
« Reply #7 on: December 14, 2018, 05:40:06 PM »
yes well, you may be right. I ve been told to seal it since it make no other work.
