Author Topic: Door Bumper  (Read 1243 times)
samdavies97
Door Bumper
« on: October 13, 2018, 09:59:30 PM »
Anyone know how to remove this door bumper?
Re: Door Bumper
« Reply #1 on: October 13, 2018, 11:03:07 PM »
As far as I can remember it slides off to the back of the car.
DeVilleChris
    • Club 126 UK
Re: Door Bumper
« Reply #2 on: October 14, 2018, 02:18:29 AM »
If its the same as mine, They've got 8 or 10mm nuts on the back of them.
Take off the door cards and then un-bolt and they pull straight off.
1979 Fiat 126 DeVille
1979 Fiat 900T Amigo
samdavies97
Re: Door Bumper
« Reply #3 on: October 14, 2018, 09:50:04 AM »
Yeah I thought they were bolted on. What have you done to hide the holes?
DeVilleChris
    • Club 126 UK
Re: Door Bumper
« Reply #4 on: October 18, 2018, 04:29:20 PM »
Well,
my car came without them originally, but i've put them back on now.
They were filled.
dmck126fsm
Re: Door Bumper
« Reply #5 on: January 15, 2019, 04:53:07 PM »
are they not clipped in
andyzeetec
  • 126 BIS
Re: Door Bumper
« Reply #6 on: January 17, 2019, 01:17:40 PM »
Yea, remove inner door trim panel and if I remember correctly there is a central retaining screw, then undo some studs, then slide the trim panel backwards to release from clips.
Re: Door Bumper
« Reply #7 on: April 11, 2019, 10:54:53 AM »
There is a central screw which you get to by removing the door panel (at least in the new FSM models). I removed mine and now its time for some WELDING .. .
Btw be carefull when removing the door cards since the little round plastic under the window lever is VERY fragile, i broke both on mine :(
