Author Topic: Bis wiring to the fast idle solenoid  (Read 508 times)
Skippy
« on: July 21, 2018, 07:57:30 PM »
Hi all
I’ve found why the first stage of the radiator fan isn’t working - the 3 cables to the fast idle solenoid have snapped off. This must have happened years ago before I bought it as the fuse is missing too. No wonder it was getting a bit warm!
I think that the black and brown should be connected to the same terminal on the solenoid, the light blue/red to the other.
Can anyone confirm that is correct.
Re: Bis wiring to the fast idle solenoid
« Reply #1 on: July 21, 2018, 08:23:04 PM »
This may help?
Thanks to all of the Subscribers Group who contribute to keep this forum running!
Club126uk Subscription Information
Skippy
« Reply #2 on: July 21, 2018, 08:29:16 PM »
Thanks but I’ve got that already. I’d really like a photo of one in situ.....
Skippy
« Reply #3 on: July 22, 2018, 01:17:32 PM »
I took the plunge and joined the grey and brown cables together onto one terminal of the fast idle solenoid and the blue/red to the other.
Now, for the first time since we bought it in 2000, we have functioning 2 stage cooling. Not that we got to stage 2 in today’s 20 mile test, but we know we have previously albeit only briefly.
Can’t believe that all this time all it needed was cables connecting and a fuse installed!
I’ve even managed to turn down the idle speed - the fast idle solenoid works.
Yay, today is a good day.
« Reply #4 on: July 29, 2018, 07:09:58 PM »
I am replacing my idle solenoid. One of the terminals protruding from the solenoid broke and is stuck inside one of the connectors. The fan is still working, but presumably just using one speed.
Skippy
« Reply #5 on: August 11, 2018, 07:51:51 PM »
Yes. Without the fast idle solenoid connected you'll only get second stage cooling that kicks in at over 100°c water temperature. Best get a new solenoid.
