Author Topic: Will not start in the mornings  (Read 1559 times)
cider
« on: May 15, 2018, 02:53:22 PM »
Think I've  found my starting issues
What's best engine in or out for gasket replacement
Sent from my SM-J530F using Tapatalk
Re: Will not start in the mornings
« Reply #1 on: May 15, 2018, 03:57:38 PM »
You can replace the bis gasket with the engine in situ the hardest part is removing the carb you need a short 10m spanner as is supplied in the standard tool kit, when mine went I used a tin of K-Seal gasket sealer which is still working in the system 🙂
cider
« Reply #2 on: May 15, 2018, 04:05:56 PM »
Just replaced the carb for the 3rd time this weekend thinking the car had over fuelling problems.
So had a thought it maybe head gasket and managed to find a cheap endoscope camera on eBay, Just need to find the motivation
« Reply #3 on: May 15, 2018, 04:41:14 PM »
Although I didn’t like using gasket seal I always had it in my boot knowing that this was a common fault, it started spewing water out 100 miles away from home but seems to have done the trick while i get the motivation to do the job properly 😀 it’s about £8 on eBay and I recommend it to anyone that has a Bis to carry a bottle just in case👍
