Author Topic: Help please - I'm assembling 126 years after I've stripped it down  (Read 1257 times)
MaLi
This is my first post on this forum for over 8 years, so it feels like I need to say hello and re-introduce myself: Hello!
Where do I start? Some time ago (when I was still young) I've had a brilliant idea to strip my 126 to bare shell and restore the shell. Which I did. And then nothing happened... I kept moving the shell with all the bits with me as I moved houses but I always had something more burning to do than assemble the shell. However, the time has finally come.
I've put the engine and gearbox in place, put together rear suspension, and started connecting electrical items. And this is where I need help. In my wisdom, when stripping the car I've binned all the little bits of plastic, screws etc. So now I'll need a bit of help to guide me into how things should be put together and what bits I'm missing.
First front headlamps.
I've got headlamps (as attached) and bare shell (also attached).
IMG_0367[1] by Maciej Cze, on Flickr
IMG_0368[1] by Maciej Cze, on Flickr
What am I missing, and how does assembled parts look like? A photo would be great!
« Last Edit: March 25, 2018, 12:59:11 AM by MaLi »
Re: Help please - I'm assembling 126 years after I've stripped it down
« Reply #1 on: March 25, 2018, 02:23:30 AM »
 :welcome Back Mali, your missing the adjuster screws that the headlights pop into
MaLi
« Reply #2 on: March 25, 2018, 07:30:21 PM »
Thanks Pete126!
a bit more browsing and it looks like I'll need 4 of those:
 http://allegro.pl/sruba-regulacji-reflektora-lampy-fiat-f-126p-nowa-i7215900169.html
and 4 of those:
 http://allegro.pl/kostka-do-srub-regulacji-reflektora-fiat-126-126p-i7239227783.html
Is that it?
More questions to come - no doubt!
« Reply #3 on: March 25, 2018, 09:19:29 PM »
Yes those are the ones :)
Bar Vitelli
« Reply #4 on: March 26, 2018, 08:46:36 AM »
Good luck with putting it all back together, it's a wonderful story and great that you are saving your 126 and getting it back on the road! Please keep the pictures of your rebuild coming, I'm hoping to learn a trick or two!  ;)
Every cloud has one...
MaLi
« Reply #5 on: March 28, 2018, 05:35:11 AM »
I've ordered loads of new parts with a bit of help (thanks mum!).
They should be with me in 2 weeks  8)
KATHMANDU
« Reply #6 on: April 10, 2018, 05:58:37 PM »
Hi although new to the 126 disease I have just started to strip down a 1973 model i got from S Italy and learning from many past mistakes I am trying to remember pics pics and more pics!! Otherwise your post will be mine in the future?
If you need pics and I have recently taken those bits apart please get in touch - here or e-mail.
For general info my no crash damage and rust free from a dry climate was not quite accurate!
Some welding has clearly been done and first signs are that the original green (now all black) is not evident under the black on the front body panels?
Other than that plus stuff yet to be discovered (this morning a chunk of bellhousing snapped off and held togther with? things could be ok
Hope to be on line fairly often to share the strip down and no doubt to ask for help
Best wishes to all
MaLi
« Reply #7 on: August 02, 2020, 10:19:09 PM »
Quick update. We're back on the road! Hooray!
I guess I should start a build thread of some sort
Guldbergdk
« Reply #8 on: August 03, 2020, 07:17:08 AM »
Beautiful. If not a build thread, then at least more pics!
andyzeetec
  • 126 BIS
« Reply #9 on: August 03, 2020, 12:49:30 PM »
Looking Good  :good:
