please if anyone has any suggestions
have fiat 126 bis from 1989 it was due its mot on monday, it is currently on a sorn so has not been driven much
got the car out on sunday and checked things lights etc
one rear indicator light not working so got a new bulb and changed this
horn and hazard warning lights not working also interior light on mirror not working
got horn taken off car and checked and it worked
replaced fuse for hazard warning lights and horn and swapped around relays and as soon as i did this the interior light worked
if i turn ignition on and press horn no sound, with ignition off no horn also
if i turn ignition on and try to turn hazard warning lights on the fuse blows straight away
didn't know if it may be due to the relays so swapped those round , once i did this the interior light came back on
don't know if i should purchase another relay and take the original horn relay out or do you think it may be a short somewhere
not in a rush to fix as car is currently sorn could get my local autoelectric mechanic to come and check but just wondered if anyone had any ideas
thanks
