Author Topic: electronic ignition Bis  (Read 11311 times)
mintex
Re: electronic ignition Bis
« Reply #30 on: January 24, 2016, 04:04:15 PM »
Its running  :wave
Been out around the village in it and i can safely say it's made a big difference to the running, it's a lot smoother and the tick over is very steady.
Dave
dadandlad
« Reply #31 on: January 24, 2016, 05:05:42 PM »
Nice
Glad you got it sorted
mintex
« Reply #32 on: January 24, 2016, 06:03:39 PM »
Very happy with the results  :)
When i was reading the instructions it says about using the thermal paste but if it comes on a base plate you don't need to but as i was removing it from the supplied plate to the bis one i put some thermal paste under it first  :)
Dave
« Reply #33 on: January 24, 2016, 07:45:58 PM »
Fantastic work! Well done :thumbup
« Reply #34 on: January 24, 2016, 08:18:30 PM »
Well done Dave! I might have ago on mine ;D
Bambino126
« Reply #35 on: January 25, 2016, 12:56:37 PM »
That does look good, I think I'm convinced!
I can't believe how fast it starts, about 2 seconds?
Mines about 90 seconds of cranking on a cold morning.
dadandlad
« Reply #36 on: January 25, 2016, 04:07:44 PM »
Got to agree with Dave the units are very good and easy to fit
« Reply #37 on: January 25, 2016, 04:18:00 PM »
I have bought a few of these units as the shop is just down the road from me. Same price a ebay though. The shop owner told me that He often has an ebay sale on Sundays only just to boost sales so keep an eye on them  :)
Ricksy1121
« Reply #38 on: January 26, 2016, 05:42:36 PM »
Iv got mine now so need to get the dizzy out and figure out how to put it together, do you need to replace any other parts?? Coil maybe?
dadandlad
« Reply #39 on: January 26, 2016, 06:27:28 PM »
Hi Rickys1121
No you don't need to replace the coil
If you are fitting the unit to a Bis distributor you need to remove the pickup from the baseplate it was supplied with
I removed my distributor and stripped out the baseplate and drilled and tapped two 3mm holes for mounting the pickup , you will need to put some thermal paste under the pickup available from RS Components which helps to dissipate the heat generated
You can pick up your positive feed for the unit from the spare positive terminal on your coil
Whatever you do make sure you connect it up correctly
All in took me about a hour from removing distributor to back up and running
I think I have a couple of pictures I will post up for you
Ricksy1121
« Reply #40 on: January 26, 2016, 07:30:42 PM »
Thanks Iv got a friend who's a mechanic so I will let him read through this and see if he will do it for me. Iv never been good with electrics so want to make sure it's done rite..
Thanks a lot!
dadandlad
« Reply #41 on: January 27, 2016, 10:10:28 PM »
Here you go
The two black marks on the rotor are the points were the magnets are mounted to trigger the unit, it made it a lot easier when timing her back up to know roughly where it should be firing
« Last Edit: January 27, 2016, 10:14:27 PM by dadandlad »
« Reply #42 on: January 27, 2016, 10:14:51 PM »
Do you need to still use a condenser?
dadandlad
« Reply #43 on: January 27, 2016, 10:16:48 PM »
No it does away with Condensor
mintex
« Reply #44 on: February 21, 2016, 02:56:46 PM »
Has anyone whos done this mod noticed if its made any difference too cold starts?
From cold now all i have to do is pump the throttle twice, give it full choke and turn the key and it starts lovley  :)
Dave
