Ok this car is starting to annoy me....
It has had new....
Complete ignition system
Full change/service
New battery, the dynamo light isnt on anymore to say its not charging which is good.
It still cuts out after running for a few minutes!!!!
So when I rev is slightly, it rocks around a bit and slows down slightly and then when you stop accelerating, it idles ok for a while.
It eventually then cuts out randomly.. Then strangly after a few minutes it will start up fine and run fine and then cut out again.. and so on and so on
I don't know what else to try really...
I'm going to reset the timing (I think its right already...)
I'm going to put new fuel lines on right the way back to the tank and a new fuel filter and go from there.
Any more suggestions would be ace!
