Author Topic: Gearbox adjustment  (Read 1642 times)
Paullou126
Gearbox adjustment
« on: January 10, 2019, 10:00:46 AM »
Hi some more help please I want to adjust my gear linkage just fitted a new gear coupling but think I need the gear linkage adjusting I believe there is two bolts that I need to slacken for this could any one tell me the location of the bolts ie left or right or both it’s a rhd 126 bis
Also the procedure thanks again
Re: Gearbox adjustment
« Reply #1 on: January 10, 2019, 12:56:19 PM »
Taken from the Fiat 500 Club's archive, the principle is the same for the 126.
https://tinyurl.com/y8zxaqw3
tomviam
« Reply #2 on: January 11, 2019, 12:09:01 PM »
Hi, if the problem is that some gear are hard to shift or they slide while driving, you need to adjust the gear lever. For that, there are 2 bolts on the right side of the gear shift tunnel, on the base.
If you find issues on the 1 or 3 gear, you need to loose these bolts and push the gear lever to the front
If you find issues on the 2 or 4 gear, you need to push it back.
Hope it helps! I had to do it myself after replacing the linkage and the clutch!
Paullou126
« Reply #3 on: January 15, 2019, 07:49:53 PM »
Hi all sorted now adjusted and now like new thanks
tomviam
« Reply #4 on: January 18, 2019, 11:19:56 AM »
how did you do it eventually?
